+ Reply to Thread
Thread: Finally something I measured up
    Oct 2011
    Culver, Oregon (Central OR)
    Lately I have been installing a lot of the salesman's measure-ups, but this one I was given the reigns to do whatever I wanted with this mechanical room. Not a surprise, the mechanical room is very tight.
    Here is some pics of my first day, slow and steady.
    Our shop doesnt hammer together the fittings unless it is a prevailing wage job.
    The S9V is my favorite Trane furnace so there is that. This job is being duct-tested so I am laying it on thick so to speak.
    Sent from my LGMP260 using Tapatalk
    May 2014
    Bay Area California
    What? It's not done yet? You had a whole day!!
    I do a triple evac with nitro to remove non condensables.
    One of our techs put in a S9X1 today. I went over and showed him how to work the setup buttons on the board so we could set blower speeds based on static. There was a Space Guard against the old furnace, he moved it to the drop and built a transition to the little opening on the furnace. Would have been a lot of work to put it on a box but we often do as our supplier sells a filter box looks like what you are installing.
    Oct 2011
    We actually get real good static on our new construction stuff but our custom homes seem to run a little high.
    On this one, the contractor only gave us 34 inches side to side in this room. There is a plumbing trap that extends 6" out from the side so I have 28" to work with. I am going to stack the furnace and tie in my supply, then measure out the return. I have enough room for a 9" wide return drop with a 1" throat. I will add turning vanes and try to keep 45s on the drop and flare out my tap at the ceiling. This is a tough one, guys.
    Oct 2011
    I will snap a pic of the mechanical room when I go back next week.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
