Results 1 to 13 of 19
    Jan 2016
    Question about insulation
    Maintenance recently replaced the insulation in my unit since the old stuff was gross and falling apart.
    Does this look like the correct insulation to you guys? Looks like regular wall insulation. The old insulation was a dark gray and more coarse. Just want to make sure they didn't mess up.
    Is there a "type" I can ask them and make sure?
    Southold, NY
    Looks fine.
    In reality you don’t need insulation in the return
    Jan 2016
    Looks fine.
    Ok thanks. Seems like it has a metallic/reflective backing on it. Just want to make sure the intake isn't pulling in some weird insulation particles or something
    Feb 2014
    Phoenix Arizona
    That type is called lung cancer.
    It should look like one of these
    But as was already mentioned, a return within the conditioned space really doesn’t need to be insulated.
    -"There always seems to be enough money to do it right the second time"
    Jan 2016
    What is the type I need called so I can tell them specifically?
    Quote Originally Posted by samgevas View Post
    Southold, NY
    Tapatalk
    Only in California!
    Jan 2016
    The pics above are what was originally there, so I'm assuming that's what it should be. Ugh. I hate these people so much
    Jan 2016
    Just had them completely remove the insulation.
    So that's ok to just leave those areas bare metal? Won't cause sweating or anything?
    Southold, NY
    Quote Originally Posted by iyiyi View Post
    Return ducts don’t sweat
    Jan 2016
    Ok. so they replaced it. Here's what it looks like now. Does this look correct/safe? Thanks so much for the help.
    Southold, NY
    That works.
    Jan 2016
    Basically I just want to make sure that the system isn't sucking in anything bad.
    Is it safer for me to just take it all out?
    SW FL
    EZ Flow type flow device can hardly be referred to as A True filter.
    The first 6 pges do not even mention a MERV # rating.
    https://s3.amazonaws.com/s3.supplyho...tion-Guide.pdf
    Many such filters are a.k.a. ' golf ball catchers ' /
    maybe suitable as a pre-filter.
    _____
    Noted in link below as MERV 4
    ______ https://www.rememberthefilter.com/collections/ez-flow
    __________
    Preferred: MERV 6 MINIMUM
    ______ https://www.amazon.com/20x20x1-Fland.../dp/B000JQLX8I
    Designer Dan
