Results 1 to 13 of 22
    Nov 2018
    HSI glowing, gas to burners, will not light on the regular.
    Hot surface igniter glows, gas valve opens and lets gas in, does not always light.
    This unit has a sealed combustion chamber. Inlet and out let are clear and free flowing.
    New gas valve because last valve's regulator went bad and was pushing out 10wc (nat gas). This unit should be 3.5wc.
    The new valve is causing the same exact issue. Glow, gas, no light (sometimes it will, and it can be lit manually as well).
    Mind boggled!
    Southold, NY
    Quote Originally Posted by RealRob View Post
    Mind boggled!
    Then it wasn’t the valve I guess!
    Sorry
    No DIY!
    Jan 2010
    Sounds like a non converted LP setup.
    If so there's more to it.
    Not a good idea to play with a gas appliance that can kill.
    Nov 2018
    This is a natural gas setup, always has been. New valve is nat gas (and it is, I dbl checked) and comes with lp conversion.
    Southold, NY
    So what’s the incoming pressure?
    Nov 2018
    Didn't bother to check the source, but to the burners it's 3.5wc.
    Jan 2010
    What's the valve make/model ?
    Nov 2018
    Robertshaw 722-079
    https://www.grainger.com/product/ROB...as-Valve-1TGD7
    Jan 2010
    and the equipment make/model ?
    Southold, NY
    So how does the valve “Increase” the pressure almost 3X?
    Nov 2018
    Empire DV40
    http://empirezoneheat.com/products/d...wall-furnaces/
    Parts and exploded view
    https://empireheaterparts.com/pdf/dv20e-40e-55e.pdf
    Nov 2018
    I was saying that the old valve had a bad regulator and was pushing out ~10wc
    Jan 2010
    So why didn't you buy the 722-052
Contracting Business
HPAC Engineering
EC&M
CONTRACTOR
