Results 1 to 11 of 11
    Oct 2019
    Dectron - Error Code 6 - Low Pressure Fault
    I have a dectron unit DSH-020-8
    A valve that flows to the unit was turned off overnight come into work today, the controller HT800 alerting me error code 4 and now 6.
    Low pressure fault (Switch Open)
    How do i resolve this please and thank you
    Jan 2010
    Unfortunately you need to apply for Pro Membership to acquire technical assistance.
    Oct 2019
    Someone is actually trying to make money off of other peoples advice now?
    Wow, humanity really is doomed.
    thanks anyway.
    Mar 2016
    NY
    Quote Originally Posted by J_Maintenance View Post
    thanks anyway.
    Pro membership is free...You’ll have to check the guidelines then apply. Dems the rules!
    Oct 2019
    Quote Originally Posted by Bombboy90 View Post
    oh its free, well that changes everything haha ty.
    And please complete your full profile, including an email address. This will allow us to get requested manuals and specs off to you should the files be too large to upload to the "PRO" site.
    Jan 2010
    The down side is it doesn't happen instantaneously.
    You'll probably have your answer before it happens.
    But wait, there's more, once you're in you're resources are endless with the vast and varied knowledge of the members of this forum.
    Apr 2003
    Maple Grove, MN
    Did you try turning the power off and then on again?
    If that works just send us a check for $275.00 and we'll call it good.
    Southold, NY
    Quote Originally Posted by ammoniadog View Post
    Today’s a holiday, Double time and a 1/2!
    Jan 2010
    Dec 2014
    As I recall, the manual lays it out pretty well for code 6 or 4 or whatever. Also Dectron tech support is only a phone call away believe it or not. Response time from them has always been under an hour in my experience.
    Sent from my SM-G950U using Tapatalk
