Results 1 to 4 of 4
    Apr 2019
    So confused - Infared heaters
    Evidently, Infared heaters only heat people & objects, but a lot of them also have thermostats on them. Why?
    I mean, what temperature is being measured if the air itself isn’t being heated?
    T
    Sep 2019
    Edmonton, Alberta
    The Radiant heater heats up the objects, the object then warm up and cause a convection cycle; the air gets heated up by the objects it’s near too and starts to rise, cold air replenishes this moving warm air and thus heating up the air temperature in the room as well.
    Think of it like the Sun being your radiant heater, a dark coloured car for example will be really hot to touch, as you move your hand away from the car slowly it’s still being warmed up.
    That’s the way I understand it anyways, most likely there are better and/or more accurate descriptions out there.
    Apr 2019
    Thank you!
    Mar 2015
    Medford, N.Y.
    Quote Originally Posted by ritchy.wall View Post
    Sounds pretty good to me.
