    Oct 2019
    Colorado
    CreCor hot box constantly trips GFCI outlet, any suggestions on the cause?
    I am having trouble with a Cres-Cor hot box model # H137UA12C. It stopped working and is tripping the gfi outlet. I replaced the switch which was a bit hard to push and still trips out.
    Any suggestions on where to look?
    Thanks!
    Jan 2010
    Oct 2008
    Yup.
    Look HERE:
    http://www.crescor.com/service/provi...search-results
    That's a list of service providers in your area.
    "You never know what others don't know." -
    If I can't laugh at myself...then I'll laugh at YOU! -
    Oct 2010
    Something more useful. Your warmer is grounding out. It could be in a compent or wiring. A person with the knowledge to walk through the steps should be able to find it quickly.
    Oct 2019
    If everything checks out on the warmer , no short then have them removed gfci and install a reg 20 amp outlet those shouldn’t be on gfci
