Results 1 to 11 of 11
    Oct 2019
    Approximate cost of compressor replacement
    Hi all,
    I am a first time poster looking for some help with approximately how much it would cost to do some refrigeration repairs in commercial supermarket refrigeration. I am engineer for a refrigeration OEM and we are trying to make some design decisions regarding replacing parts more often versus making them significantly more resilient to failure (at a steep increase in cost). I was wondering if anyone has an approximate (i understand it is going to be large range based upon specific circumstances) cost for how much it would cost to replace a failed compressor (time + material) on a supermarket compressor rack? I am seeing numbers ranging from $xxxxx. Does that seem right?
    Thanks for all your help!
    Yes.
    Quote Originally Posted by tmodi View Post
    Hi all,
    I am a first time poster looking for some help with approximately how much it would cost to do some refrigeration repairs in commercial supermarket refrigeration. I am engineer for a refrigeration OEM and we are trying to make some design decisions regarding replacing parts more often versus making them significantly more resilient to failure (at a steep increase in cost). I was wondering if anyone has an approximate (i understand it is going to be large range based upon specific circumstances) cost for how much it would cost to replace a failed compressor (time + material) on a supermarket compressor rack? I am seeing numbers ranging from $xx. Does that seem right?
    PHM
    Aug 2015
    Buffalo,NY
    Lots of variables. Compressor type and size. Refrigerant type and amount. Recovery time. Accessibility. Evacuation time. Do I need a crane or a rope. 2nd guy/helper. Compressor under warranty. What caused the compressor to go bad.
    I dont even know how you could expect a realistic guess without giving some hypothetical specs.
    Paint me a picture.
    kansas
    You can get more details,but the most you will receive is approximate hours. Cost and prices are not discussed here
    Southold, NY
    Hi all,
    So
    Are you going to post some details?
    Sep 2003
    upstate sc
    it's a supermarket compressor Rack. Find a reputable Contractor with a good Rack Mechanic or 2. Pay them what they quote you. Stick with them for years,and pay them on time.because they will only make your refrigeration better.
    Example: Old frankenstein rack. Compressor breaks, get compressor replaced in 3/4 day. Come back the next day start trying to figure out what caused it to break..I did say start. Set superheat on a couple Txvs, just happen to find and repair a few refrigerant leaks. Set defrost times,and EPR's. See where this is going.. Yes it gets expensive, your refrigeration equipment starts to work better, and slightly more efficient. before long you find that your service calls decrease. Then it's time to get on a P.M. Program.
  7. Likes Metalman0880, kamersoutdoor liked this post.
  8. #7
    Nov 2019
    You'd better ask the live specialist, lack of data to answer
  9. #8
    Nov 2019
    Comes down to location, space for work, ease of setup, and weight. Depends whether it's on a roof/crane setup; first floor/second floor; on a lower rack/upper rack; setting back up safeties; wiring. Can make the difference of two guys doing it right in half a day, versus two or three guys taking all day from complications.
  10. #9
    Nov 2019
    Quote Originally Posted by bigdmike View Post
    I like you. Couldn't have said it better. Specifically as someone who heavily advocates for PM programs... Cheers
  11. #10
    Dec 2000
    Id think youd have to check each system for size, refrigerant, etc., then get costs of what youd want to change, then add it all up. A small system compressor is way less than I large one. So kinda impossible to just try estimate.
  12. #11
    $12,383.56
  13. Likes BALloyd liked this post.
Tags for this Thread
Contracting Business
HPAC Engineering
EC&M
CONTRACTOR
