Results 1 to 8 of 8
    Oct 2019
    Tempstar 95% furnace is short cycling
    I have a tempstar furnace. 95%. I it will run for 5 minutes then the flames kick out. The fan will continue to run for a couple minutes then it will fire again. Nothing is blocked. Filters are clean. I even ran it with out any filters or anything thinking maybe there was an airflow issue. It will did the same thing. Pressure switch was replaced, but didn't help. Somebody had a thread about this same problem 3 years ago. Any help? and if by chance that guy sees it, did your problem get fixed?
    Time for a call to a service professional for a system check.
    Athens, Ohio
    Sounds like an air flow issue. Have a tech check static pressure and temperature rise.
    AOP Rules: Rules For Equipment Owners.
    Free online load calculator: http://www.loadcalc.net/
    There = not here. Their = possessive pronoun. They're = they are
    It's = contraction of it is. Its = the possessive form of it
    Too = also. To = expressing motion. Two = 2
    Then = after that, next. Than = indicates a comparison.
    Questions should end with a question mark "?" Statements end with a period "."
    Oct 2019
    Quote Originally Posted by kdean1 View Post
    How would one fix an airflow issue?
    Athens, Ohio
    Quote Originally Posted by clerc86 View Post
    One would increase air flow.
    Southold, NY
    Whats the Static Pressure?
    Virginia
    Systems will lose airflow over time due to dirty components within the unit, failing motors, duct work problems, and restrictive air filters.
    It is the techs jobs to perform a series of test to determine which one it is, and correct the problem.
    Mar 2018
    Chico, Ca #StateofJefferson
    How's your drain line?
