Results 1 to 8 of 8
    Oct 2019
    Can anyone recommend 4 ton light commercial/residential compressor that uses copper?
    Can anyone recommend a good 4 ton light commercial/residential compressor that uses copper?
    I have heard that Microchannel are hard to repair and have a lot of issues.
    Thanks.
    Split unit? Easy to find units with copper tubing in their coils. Nortek brands and some Yorks will be the exception. Packaged units, gotta watch as more of them are microchannel. We did a 4 ton Carrier/ICP packaged unit with copper, Lennox tends to be microchannel.
    Madison, WI/Cape Coral, FL
    Tell us about the negative about mirco-channels.
    Regards Teddy Bear
    Atlanta GA area
    Do not know about Lennox package units...
    However the split system units (both indoor coils and outdoor units) are aluminum tubing.
    So far, they are working well... we will see...
    GA-HVAC-Tech
    GA's basic rules of home heating and AC upgrades:
    *Installation is more important than the brand of equipment
    *The duct system keeps the house comfortable; the equipment only heats and cools (and dehumidifies)
    *Cheap is not good, good is not cheap; however expensive is not a guarantee of quality!
    Choose your contractor wisely!
    Oct 2019
    Split system.
    Can you recommend a good brand(or are they all the same?)
    I like copper over microchannel.
    Thanks.
    Atlanta GA area
    There is another option...
    Aluminum NON micro-channel coils...
    Lennox does this... conventional design, however aluminum round tubing rather than micro-channel design.
    Then there is the AlliedAir products...
    Lennox clones... good value for the $$$!
    GA-HVAC-Tech
    Everyone has their own preference on what's good. I don't like builder models with no features. This summer we sold a lot of American Standard equipment, same as Trane. Even the standard line is relatively quiet and has high & low pressure switches protecting the compressor. Since our climate doesn't justify high SEER, this 13 SEER line is a good deal. But mid line of most brands would do you well. Again, watch York for MC and Nortek brands use it on all outdoor units, they were using them on heat pumps, not sure if they still do. They also use it on their A coils too.
    Atlanta GA area
    Last week, pulled and trashed a 2015 Nortek brand AC/coil... both MC... leaking like a sieve!
    GA-HVAC-Tech
