Results 1 to 7 of 7
Thread: Proper way?
    Nov 2008
    Long Island NY
    Proper way?
    How many of you guys do this? The Guru wants to know. Aka Superheatmaster.
    Sent from my SM-G965U using Tapatalk
    Southeastern Pa
    My lunch is done with my micron gauge says 500.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  3. Likes Metalman0880, Fender60 liked this post
  4. #3
    When I worked out of Local 322 it was common.
    So it was always better for the customer to have the evacuation performed on Friday. <g>
    Quote Originally Posted by Jettinvr6sc View Post
    PHM
  5. #4
    Mar 2015
    Tx
    Quote Originally Posted by timebuilder View Post
    I thought anything higher than 400 microns was a leaker
  6. #5
    Sep 2019
    Northeast
    My lunch is done when my vacuum is done milk man
  7. #6
    New Mexico
    Just on how vacuums are done in the industry causes me to wonder how important they are.
    If shops are not really pulling adequate vacuums by industry standards shouldn't there be way more problems?
    I like vacuums myself but I also know some must not.
    Carrier might have suspected that vacuums were often not done or only partially when they advised the triple evacuation. Today the method is misinterpreted but a good idea in it's day.
    There are ways to remove moisture a lot faster and more complete but each seems to have a down side.
    Give me a relay with big enough contacts, and I'll run the world!
    You can be anything you want......As long as you don't suck at it.
    If a person wants to create a machine that will be more likely to fail...Make it complicated.
    USAF 98 Bomb Wing 1960-66 SMW Lu49
  8. #7
    Apr 2003
    St. Louis
    There are industry standards and industry practices. Standard what is 100% correct, practice what ever it takes. Every company is different just like service people. The newer refrigerants vrs older refrigerant will push the companies to do the right thing. R22 used in high temp ac was very forgiving. Worked for a factory sevice on residual 22 servicemen not one vacuum pump purged everything. Had very few problems in pre reclaim days.
