    Connecticut
    Siemens Workbench Platform Daemon
    My Siemens Workbench 4.7 platform daemon is stuck in startup and will not run. When I run the daemon from the start menu it says installed successfully but I cannot transfer a station to the local host. Anybody seen this?
    Connecticut
    Finally got it working. Had to manually run the daemon from the console. When I try to transfer a station to my local host so I can run it on my PC, I get this error. Any ideas?
    Transfer failed.
    com.tridium.platform.daemon.DaemonResponseExceptio n: Request to platform daemon at localhost failed:
    bad return code to commit file instance
    at com.tridium.platform.daemon.DaemonFileUtil.transfe r(DaemonFileUtil.java:650)
    at com.tridium.install.InstallScenario.commit(Install Scenario.java:1270)
    at com.tridium.platDaemon.ui.stationtransfer.FinalSte p.run(FinalStep.java:341)
    at java.lang.Thread.run(Thread.java:748)
    Oct 2019
    London
    Same Issue
    Quote Originally Posted by The Reaper View Post
    Transfer failed.
    I have the Exact same issue, Did you manage to resolve it? We have the Daemon running and even tried new Certificates.
    U.S.A.
    I'm getting that same error. Did you resolve your error? I can copy other stations successfully but not this one in particular.
    Connecticut
    Quote Originally Posted by tuncos View Post
    It seems to only happen when it's a station that I didn't create. I ended up rebuilding it on my PC and the problem went away.
  6. Likes tuncos liked this post.
Contracting Business
HPAC Engineering
EC&M
CONTRACTOR
