Results 1 to 11 of 11
    Jan 2015
    Bellevue, Washington, United States
    Mitsubishi 3.5 ton Condenser
    Name:  Brit Heat Pump.jpg
    I installed this system in Seattle last week for a friend. They got a 3/4 wall unit upstairs and a 2 ton air handler downstairs. The system was VERY quiet. I has to be set up differently than a regular air handler because it uses different controls. After I got it up and working I found paint for the line hide and made it look like it had always been there.
  2. Likes dbacmc liked this post.
  3. #2
    State College, PA
    I have painted the line hide before and really gives that finished look.
    I also painted the white line set so it all just disappeared.
    have a pic of the indoor air handler?
    Can someone please explain to me -
    Why is there never enough time to do it right the first time, but plenty of time to do it twice?
    Please view site rules: http://hvac-talk.com/vbb/showthread.php?t=1241
    Apply for Pro Membership: http://hvac-talk.com/vbb/showthread.php?t=116113
    Find your local HVAC-Talk Contractor: http://hvac-talk.com/aop
  4. #3
    Oct 2011
    Gladstone, Oregon (Portland)
    I keep telling everyone I know. Those wall brackets are the prettiest and most solid way to mount those things. Looks awesome.
  5. #4
    State College, PA
    Quote Originally Posted by Adlerberts-Protege View Post
    I use wall brackets on every mini I can. Keeps the condenser off the ground and out of harms way as well as looking good.
    I even wall mound conventional condensers if I have a brick or concrete wall.
  6. #5
    State College, PA
    I also like using a surge protected disconnect. I use Mars. Probably not the best but better than nothing.
  7. #6
    Oct 2001
    Wakefield, MA
    Quote Originally Posted by James Colver View Post
    What did you do for controls? Would love to see a photo of the air handler install as well...
  8. #7
    State College, PA
    Now wait a minute... I see a 110 outlet coming out of what is most likely a 220 disconnect. What is going on there?
  9. #8
    Service outlet for the tech to use his vac pump or light if at night its better then the cheater or widow maker cord some use
  10. #9
    State College, PA
    Quote Originally Posted by pctech View Post
    My point is, how is is getting 110 from the 220 disconnect?
    Is he using the ground wire as the neutral?
  11. #10
    Nov 2008
    Long Island NY
    Quote Originally Posted by joemach View Post
    Either they ran a separate circuit or a single neutral in a perfect world.
    Sent from my SM-G965U using Tapatalk
  12. #11
    Mar 2018
    Maryland
    Looks good but be careful pointing the discharge towards a walkway. They will make walkways into a sheet of ice during winter months. Which explains why sometimes you see them facing the wall (backwards looking) by municipal buildings with sidewalks by the unit.
