Results 1 to 2 of 2
    May 2011
    Fort Lauderdale, Florida
    chilled water coil replace
    Has anyone disassembled a trane AHU enough to remove the chilled water coil?
    It is a CLCH climatechanger, size 3. it looks like it can be removed from the side opposite the plumbing, or from the top.
    The sheet metal is a bear to remove due to the butyl tape on the seams. I want to remove just the necessary panel(s) instead of exploring by disassembly.
    Has anyone any advice?
    SW FL
    GOOGLE
    ______ PERFORMANCE CSAA IOM
    Trane Performance Climate Changer CSAA Series Installation, Operation And Maintenance Manual
    ____ for TRANE documents.
    + CALL local TRANE office
    https://www.trane.com/commercial/nor...-handlers.html
    Designer Dan
