Results 1 to 8 of 8
    Sep 2019
    new system oil separator precharging
    Good evening to all. My first post ever. Please bear with my inexperience. Fortunately Im a quick learner, so I wont disturb you for too long with my unintelligent questions.
    Im tasked with assisting a another tech with a system start-up: a walk-in cooler 25 HP system. Piping length about 60 feet. The semi-hermetic indicates oil in the sightglass. There is a sealed type oil separator in the discharge line. I remember from school days that separators must be pre-charged with oil prior to start-up. My tech said that this pre-charging was probably done at factory, but not really sure. Is he assuming things correctly?
    Just in case we need to do the pre-charging, I do not see any ports in the separator for adding the oil. Should we just braze a Shraeder type fitting in the piping or is this done through the oil return line? Ive read that there is a float controlled needle valve that will not allow oil through backwards. Please let me know any suggestions.
    Jan 2010
    What's the motor make/model if the separator ?
    Here's some Emerson models and their charge amount.
    Southold, NY
    and I was going to say
    What does the IOM say?
    Jan 2010
    What's going on over there ?
    Mar 2015
    Medford, N.Y.
    Hey VTP99. Do you have an Emerson Form# for that info that you provided. It seems that my Library is lacking that info. Thanks.
    Jan 2010
    Quote Originally Posted by TechmanTerry View Post
    Mar 2015
    Medford, N.Y.
    Thanks Bro! It's already filed and added into my Library.
    Sep 2019
    thank you very much!!
