Results 14 to 24 of 24
Thread: Carrier QC
    Aug 2009
    Beatrice, NE
    Quote Originally Posted by Spitz View Post
    I've seen some mistakes on new units from the factory. Wires landed to the incorrect terminal, txv bulbs strapped to the wrong suction line and so on. We are in the process of installing 3, 10 ton RTUs they are 3phase but run single phase ECM condenser fan motors. The low voltage for the ECMs come off the main board. One of the fans would not run. We found both plugs have Male pins and they were just rammed in. We checked the other two new units and they were wrong also.
    Didn't they pack the female jumper in with the instructions?
  2. Likes The Turtleman liked this post
  3. #15
    Oct 2011
    Chicagoland Area
    Funny thing is she the one with the dirty mind
    I got a call to a Jenny Craig the freezer was leaking water. I tell the 40 something cougar of a manager that the nipple on the drain pan is cracked. She laughs, tells me her husband is a plumber and she knows all about nipples and cocks.
  4. #16
    Jul 2018
    Wisconsin
    Quote Originally Posted by BNME8EZ View Post
    No, there should be no reason at all for that. They put the wrong ends on in the factory.
  5. #17
    Aug 2018
    Piedmont Triad, NC
    Wait till your piping a gas line and the wrong person hears you tell your helper you need the tray of black nipples......
    I know it’s childish but I snicker every time I ask my helper for a close nipple or 2” nipple, etc.
    It’s even worse when I work with someone with an accent that turns “caulk” into “cock”. I couldn’t help but laugh when I heard him say: “I need more cock.”
  6. #18
    Aug 2008
    Hibbing, MN
    Been having issues with Carrier RTU's as well.
    Last one was flat on change ( leak at compressor suction stub ) and another has VFD issues.
    I just had a Bryant with the exact same problem. Leak at compressor suction stub. How does a leaky unit leave the factory? Added 3 hours to my install! Also, same unit had male to male wiring for the economizer.
    If God didn't want us to eat animals... He wouldn't have made them out of MEAT.
  7. #19
    Jan 2010
    Quote Originally Posted by GenesisRefrig View Post
    It use to be each unit came with a factory run/test sheet.
    Funny how you don't see that any more.
  8. #20
    Nov 2011
    East Side
    I worked at a plant for a huge multinational corporation. they were informed that the electrical connection boxes on motors were no longer peckerheads, they are now pumpkinheads!
  9. #21
    Jan 2010
    Sea to Sky
    I see quality control sheets that have obviously been pencil whipped all the time since there are obvious defects. Lol
    Sent from my SM-G965W using Tapatalk
  10. #22
    Oct 2019
    Peoria, IL USA
    wtf?! ppl actually do this shit? OMG if a female got offended by the terms "male" and "female" (referring to pins/holes) I'd ask her why she chooses to get offended by that and ask her what she thinks should be done about it. if she suggested that everybody change terminology, I'd tell her: it would be 1000X easier for you to change your feelings such that you're not offended by the terminology than to have everybody else change their terminology.
    Quote Originally Posted by Opcom View Post
    male pins on both connectors from the factory. wow reminds me of where I worked as an engineer leading a team of technicians in the 90s. They got an HR employee due to a government requirement for contract bids, and suddenly all PC and sensitivty hell broke loose and they brought in a new supervisor filled with bright ideas but endowed with little technical knowledge and no common sense. This disaster was inserted between our manager and us.
    A total waste because our manager already did almost nothing except sit and stare at his computer all day, hardly even moved because we knew our jobs and did them. They could have hired a couple more techs and increased output and profitability. But no, don't do that, just shoehorn more layers of management into every crevice.
    Anyway the new supervisor was under pressure to document some sort of positive 'sensitivity improvement' and proclaimed that we were to say 'pins and holes' because someone might think 'male and female' connectors were sexist and be offended.
    This was ridiculous and led to "holes" being mispronounced by the technicians, like that long-handled gardening implement. Not going to get into what was joked about when a new design was released using a board with a row of connectors having all the same connector shells to save expense - but they had both pins AND holes, in 5 or 6 different patterns to prevent misconnection of cables.
    4 months later they hired a female tech. The guys quit the joking around out of courtesy, but it didn't take her long to dislike the term "hole" being used to replace the term "female" on general principles and we were asked to go back to the original industry standard terminology after Mr. Supervisor was advised by his boss that the electrical term "receptacle" wasn't a great idea either. The supervisor didn't like the snickering at his expense from both beneath his position and above it.
  11. #23
    State College, PA
    Quote Originally Posted by RamiRustom View Post
    Female= innie
    Male= outie
    Have to be gender neutral.
    Can someone please explain to me -
    Why is there never enough time to do it right the first time, but plenty of time to do it twice?
    Please view site rules: http://hvac-talk.com/vbb/showthread.php?t=1241
    Apply for Pro Membership: http://hvac-talk.com/vbb/showthread.php?t=116113
    Find your local HVAC-Talk Contractor: http://hvac-talk.com/aop
  12. #24
    Aug 2018
    Piedmont Triad, NC
    O M G! Your lack of empathy is TRIGGERING ME!! QSHgcjjketujbddrukkowsshjhtfhj!!!!!
    At least that seems like how they’d react based on some YouTube vids I’ve seen. Although I forgot to call you racist and fascist so I guess I’m not cut out for this.
