Results 1 to 7 of 7
    Sep 2019
    Navien hot water heater
    I am in Ontario however don’t think it matters. Flex gas connectors like what you would see on the back of a stove hooked up to a Navien hot water heater. I have never seen this connector used for anything other then a stove and gas dryer. If this was legal than we would scrap expensive gastite fittings. Someone tell me I am wrong and this is legal where they are from.
    Mn the state where absolutey nothing is allowed
    just because its legal doesn't mean its not stupid......
    did you have an actual question?
    my boss thinks its possible to repeal the laws of physics
    Jul 2013
    Richmond, VA
    I mean, if it carries the rated capacity, what's the difference if you use Gastite or an appliance connector?
  4. Likes Vinnie_NJ liked this post
  5. #4
    Sep 2015
    Ontari-ari-ari-o
    The code doesn't say that you can use them like that.
  6. #5
    its called a WATER HEATER not a hot water heater if it was allready hot you would not need to heat the water
  7. #6
    Jul 2018
    Wisconsin
    Just put in A NTI boiler and the instructions say to use a flex gas line if approved by local code. This is so stress on internal components is not possible.
    Sent from my SM-G960U using Tapatalk
  8. #7
    Athens, Ohio
    I don’t know why anyone feels a need to heat hot water. It makes more sense to heat cold water to make it hot.
    AOP Rules: Rules For Equipment Owners.
    Free online load calculator: http://www.loadcalc.net/
    There = not here. Their = possessive pronoun. They're = they are
    It's = contraction of it is. Its = the possessive form of it
    Too = also. To = expressing motion. Two = 2
    Then = after that, next. Than = indicates a comparison.
    Questions should end with a question mark "?" Statements end with a period "."
  9. Likes BALloyd liked this post
