Results 1 to 8 of 8
    Jun 2012
    Northeast
    Question Pum Down Settings AC
    Wondering what you guys set your low pressure switch at for R-22 and R410-A. Cut in and Cut out
    Southold, NY
    Quote Originally Posted by Push It View Post
    The ambient conditions play a big part of it!
    Jun 2012
    Northeast
    Could you explain? Are you referring to the the units available condenser space?
    Jan 2010
    Are you using it as a safety or freeze protection ?
    Oh wait you said Pump Down correct ?
    Which gas because pressures matter ?
    Jun 2012
    Northeast
    Yes pump down. I have only dealt with R-22 units that I see a pump down on. Haven’t seen a 410A System yet with a pump down. But wondering on both.
    I am wondering more for larger tonnage units that have reciprocating compressor with pressure unloading cylinders.
    Oct 2011
    Chicagoland Area
    Apr 2003
    St. Louis
    What type of compressor scroll or recip? Scroll wouldn't have any. Recip 35 with 20ld diff.
    Mar 2015
    Medford, N.Y.
    Quote Originally Posted by servicefitter View Post
    Why would that be? I have done a lot ever since they have been on the market. And that even includes when Cope did not put in an internal check valve in the Scroll and I had to install an external check valve. That was way back when the Scroll 1st came out.
