    Mar 2018
    Restoring AX station from a backup .dist file
    Like the title says, trying to get the station back up after a Jace died. The dist file has content, but when converting to a .zip format, windows says there's nothing to extract. Am I up a creek here?
    Kenilworth NJ
    Look at the size of the file. If the size is 0, then yes. You are out of luck. I have had JACEs give me a backup that is 0kb from time to time, usually when they are almost dead already.
    Hmmmm....smells like numbatwo to me.
    Mar 2018
    Quote Originally Posted by numbawunfela View Post
    Nope, both the dist and the converted zip show about 3mb.
    Kenilworth NJ
    Usually they do extract just fine... the fact that it does not is likely all you need to know. However, you can restore from .dist without extracting it. Use the platform's distribution file installer to install that .dist backup onto the replacement JACE. If that does not work I dunno what to tell ya.
    Jul 2005
    Wisconsin
    When you were "converting from a dist to zip" is it through some utility or just by renaming the file extension? I would just install the .dist, but if some program is having trouble just try manually changing the extension.
    Mar 2018
    Quote Originally Posted by theintegrator View Post
    I just renamed it.
Contracting Business
HPAC Engineering
EC&M
CONTRACTOR
