Results 1 to 8 of 8
    Jul 2013
    Richmond, VA
    Sealing windows temporarily
    I rent a unit in an apartment building, which has very leaky windows. Summer isn't a problem because my A/C barely runs throughout the day, but in winter it contributes to a lot of heat loss. Each year I usually put a bead of tape over the gaps to keep them sealed.
    This year I was thinking of sealing them with silicone or something, but it can't damage the paint or framing and easy enough to remove so I can open the windows when winter is over. Would silicone work or is there something else I should look at?
    Aug 2015
    Buffalo,NY
    Why not that plastic shrink wrap stuff with the double sided tape and a hair drier.
    Jul 2013
    Richmond, VA
    Quote Originally Posted by Metalman0880 View Post
    Hmm, that’s a good thought. I’ll look into that.
    Apr 2003
    Maple Grove, MN
    Yeah do that, but get yourself some of this stuff first...
    If at First You Don't Succeed, Skydiving Is Not for You.
    Jul 2013
    Richmond, VA
    I was reading about something called rope caulk. Apparently it's kind of like a putty that comes in a roll and you stuff it in the gaps. I'll try out that Seal 'N Peel too, see which one works best.
    Jul 2012
    WA
    Plumbers putty would work.
    in a house, Appomattox, Va.
    was thinking same thing, hardware box store has it with weatherstripping stuff.
    Col 3:23
    Oct 2019
    USA, Seattle currently
    Quote Originally Posted by CircusEnvy View Post
    We used those as well.
    Any good hardware store will carry the shrink-wrap plastic. It comes in individual pre-cut window size and also in big sheets that you cut to fit. Measure your windows and compare to the sizes mentioned on the shrink-wrap package.The package includes double-sided tape for attaching to the window frames. Try to cover the entire frame (wrap to edge, or around edge if possible). You'll need a hair dryer to "shrink" the plastic and make the windows "clear". However, it's no big deal if you don't shrink it; it will just look wrinkly.
    Just be careful with the hair dryer because you can actually melt the plastic if you don't keep moving the dryer around, at a distance from the plastic.
Contracting Business
HPAC Engineering
EC&M
CONTRACTOR
