View Poll Results: What is the cause of Control Board Failure
Voters
3. You may not vote on this poll
  • Only the rates chewing the wire? size of fuse doesn't matter
    1 33.33%
  • Rats chewing wires blowing higher rated 5 amp fuse
    1 33.33%
  • number of times the 5 amp fuse was blown within a short period of time
    0 0%
  • Would the issue be the same if only 3 amp fuses during troubleshooting?
    0 0%
  • Did using 5 amp fuses cause the 24v side of transformer to melt?
    0 0%
  • Does using 5 amp fuse void the warranty?
    0 0%
  • Technician's responsibility for control board failure?
    1 33.33%
Results 1 to 13 of 17
    Sep 2019
    Acceptable Trouble shooting practices
    Recently an AC technician responded to my call after I noticed the thermostat no longer displayed information . . . Well, Here's what happened . . . Please review the attached PDF and let me know your opinion as to why the control board fried . . . I'm ready to answer any questions needed . . .
    Fixed thread.
    Feb 2011
    Georgia
    Fix the rat problem. The 5 amp fuse did not cause the board to fry
    Who is Horizon, "... reported to Horizon..."?
    None
    All
    Other
    Quote Originally Posted by pacnw View Post
    A large service company.
    Sep 2019
    The board and the Transformer failed after for 5 amp fuses blew within about 15 minutes . . . Are you saying that the board components would not be affected by so many hits? The last occurrence did not blow the 5 amp fuse but that's when the board circuitry went open. Rat problem fixed!
    Sep 2019
    I meant FOUR 5 amp fuses blew!
    It might have had an effect, it might not have.
    The outdoor unit control wiring short does not actually go through the circuitry of the board.
    Feb 2011
    Georgia
    Going through so many fuses is only a sign of inexperience. Hardly any evidence that you are owed any freebies
    Southeastern Pa
    An "out of spec" 5 amp fuse would not cause a board to die. In order to give a better cause than the rats chewing on the wire, I would have to posses a service history where I was the tech doing the work. Boards fail often, and without any fuse changes or fuses blowing. Sometimes, an examination of the board can suggest a cause, but since the board is generally not repairable, those investigations are rare.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    I could see using 5amp fuses could have caused undo stress on transformer, though transformer may have already had damage from age or intial rat caused issue.
    However, the circuit board will not be damaged from a 5amp fuse. That is purely coincidental.
    Major rat issue was your main issue. Go after the rats for cost issues.
    Southeastern Pa
    It is also worth noting that a transformer can burn up without ever opening its protection, when the current is consistently high but just under the protection value, allowing enough heat to accumulate from a turn to turn short that it eventually reaches the point where it pulls enough current to let the smoke out.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
