Page 2 of 5 FirstFirst 12345 LastLast
Results 14 to 26 of 53
    Mar 2016
    Dayton Oh
    Best to stay in the same HP range. Bigger HP are to run bigger fans/more cfm.
    What about correct RPM? You went from 3-4 speeds to one speed? We know we’re moving enough air?
    What about fan speed for a/c.
  2. Likes Metalman0880 liked this post.
  3. #15
    Southold, NY
    Quote Originally Posted by wxguo1 View Post
    I may have overlooked. I thought using higher HP to replace lower HP would be OK.
    There’s a reason the manufacturers choose a size!
    Search for Fasco Motor Facts.
  4. #16
    May 2019
    Are the unused speed taps isolated/insulated from the power?
    If you somehow energize more than one tap the motor OL would cut out.
    Are voltage, rotation and run cap correct?
  5. #17
    Aug 2009
    Beatrice, NE
    Quote Originally Posted by RLJN View Post
    Generally if you energize more than 1 tap you will get more than just an OL opening.
  6. #18
    No, an under loaded PSC motor doesn't do well. They tend to over heat.
  7. #19
    Jul 2018
    Wisconsin
    Rescue motor has a HP range. It changes depending on the cap you use.
    Sent from my SM-G960U using Tapatalk
  8. #20
    Aug 2015
    Buffalo,NY
    they are both furnace blower motors. I have only two wires, black and white.
    So you replaced 4 speed (unknown hp) motors at the moment with 1 speed motors? You don’t know if hp ratings are the same? What are they doing for heat/AC? Are they only heat only? If not someone’s going to open high limit when they want heat.
  9. #21
    Jul 2011
    DFW, TX.
    I wonder if the evap coils are dirty/clogged.
    Sent from my LG-G710 using Tapatalk
  10. #22
    Southeastern Pa
    You can use the link in my signature line below, "how to become a professional member," in order to get all the details...and once you have the required number of posts, THEN you should submit your credentials..... not before.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  11. Likes thatguy liked this post.
  12. #23
    Sep 2019
    Definitely sounds like it's wired wrong....better check the schematic again and verify proper rotation....if it happened twice and they were both universal it definitely sounds suspect
  13. #24
    I wish all motors only had black and white ...
    You need to have someone help you buy the correct motor
  14. #25
    Jan 2010
    Image had he been up against a ECM
  15. #26
    What was the rated amp draw of the old motors?
    What was the rated amp draw of the new motors?
    What was the actual amp draw you measured?
    What was the rated voltage of the old motors?
    What was the actual voltage you measured?
    PHM
    I have two customers whom I replaced the blower motors for them. Interesting and frustrating, in both cases approximately two hours after I left, the motor stopped working again. When I tested the motors, the windings seem OK, but the motors are all very hot, not working anymore, even if directly connected to power line. capacitors are good. I used universal motors(two wires not including the capacitor wires) to replace the four wires motors. Anyone could point out what I did wrong? Thanks ahead!
    PHM
Tags for this Thread
Contracting Business
HPAC Engineering
EC&M
CONTRACTOR
