Results 1 to 4 of 4
    Sep 2009
    Feb 2017
    New York
    You could replace the cartridge. If it doesn't come with a new screw, match one up at HD or somewhere.
    Sent from my SM-G935U using Tapatalk
    -----Stop, step back, relax and have another go at it.-----
    Sep 2009
    cant get it out
    New Jersey
    They make a tool that you insert into the two flats that allows you to spin the cartridge. Usually after you are able to spin the cartridge, it frees it up.
    Check with a good plumbing supply house for this tool. If you get a replacement cartridge it comes with a plastic tool, the plastic tool will break, ask for a metal one. Also penetrating oil will help to free up the rubber gaskets.
    Sent from my ASUS_P00J using Tapatalk
