Page 5 of 8 FirstFirst 12345678 LastLast
Results 53 to 65 of 96
  1. #53
    Atlanta GA area
    My torch is towards the literal center of the cargo area...
    The spare acy is about 5 ft from the spare O2...
    The spare O2 is close to the back where the N2 are...
    The spare acy is not far from the torch... difficult to get injured from a crash.
    I have a stiff cardboard cylinder that I tape over the valve of the spare acy bottle.
    And I am a fanatic about shutting off the bottle valves and draining the hoses of the torch!
    Do it when I finish welding... and ALWAYS look at the gauges on the torch kit when it goes back into the van... they MUST all read zero... or the torch does not go back into the van!
    GA-HVAC-Tech
  2. #54
    Jul 2012
    WA
    If I’m doing service I put stuff away after each call and bill the customer. If I’m on an install I organize and restock once the install is done and bill for my time. I don’t like organizing my van on my own time. My floor isn’t clear, but it’s not piled high. I do have room to move through it.
  3. #55
    Jul 2012
    I'm not supposed to butt in here but I showed this mod to my residential a/c guy so I can share it among associates.
    Screw some 1" wide x 1/8" thick aluminum bars all the way from side to side near the van ceiling, snugging them up to the underside of the horizontal areas of the body above the tops of the shelves. - The horizontal surfaces indicated by the arrows, but we did it up front.
    Space them how you like -on his we put 4 of them 18" apart starting behind the crash wall. There's a good 3-4" vertical space under the roof there that's otherwise wasted. Think of it as the attic.
    2-3 small alumnum pieces left over from the job were screwed vertically to the crash wall so the flters wouldn't come forward over it.
  4. #56
    May 2014
    Bay Area California
    Looks like your vacuum pump oil is dirty and the level is low. Probably should consider changing it a couple of times.
    Quote Originally Posted by Opcom View Post
    If you were a real tech, you'd solder a relay on that board and call it good to go.
    I do a triple evac with nitro to remove non condensables.
    I use 56% silver on everything except steel.
    Did you really need the " If you were a real tech " ??
  5. #57
    Oct 2005
    B.C. Canada
    Its actually fresh and not low, must just be the angle its sitting
  6. #58
    May 2014
    Bay Area California
    Come to think of it, my oil looks low until I turn the pump on.
  7. Likes Fender60 liked this post
  8. #59
    Mar 2018
    Sumter, SC
    Quote Originally Posted by BBeerme View Post
    LOL, not my pump. I havent been assigned a van yet.
  9. #60
    Dec 2006
    Vancouver, B.C.
    Had to ride with this the other day
    Quote Originally Posted by Fender60 View Post
    So so far my first HVAC job isnt going that great. The other day I was assigned to work with the tech that works out of this van.
    Is that the new Honeywell 5K 55 wide screen surround sound 3D thermostat? Kinda daring leaving copper fittings sitting up top above it like that.
    Quickly, I must hurry, for there go my people and I am their leader!
  10. Likes Core_d liked this post
  11. #61
    Jul 2012
    WA
    What’s the deal with the tv?
  12. #62
    Mar 2018
    Sumter, SC
    Quote Originally Posted by Red Man View Post
    Whats the deal with the tv?
    Wish I knew. We went by his house on the way to a job and he put it in the back.
  13. #63
    in a house, Appomattox, Va.
    took me a second to see tv, I was looking for a big box- crt vs flat screen.
    took some pics of van today after cleaning up some and culling out a box or two of extraneous stuff.
    Col 3:23
  14. Likes Fender60 liked this post
  15. #64
    Oct 2016
    Timmins, ON
    Just reading through some old posts, thought I'd share my setup. I'm an insataller if that makes any difference
    Sent from my SM-G903W using Tapatalk
  16. Likes captube liked this post
  17. #65
    you need better cars mikey lol never seen a roach in any van i own but i get them new most of the time or from somone i know and trust for this reason
