+ Reply to Thread
Results 1 to 15 of 15
Thread: First time for everything
    State College, PA
    Had a call that the condenser was kicking the breaker as soon as it came on. Customer called an electrician and was told it was most likely a shorted compressor. I was thinking maybe bad breaker. So I ask her what size and make and pick one up on the way to the call.
    Get there and check condenser first. Pull cover and see capacitor bulging. Check Mf =0. Put in new cap and all is well.
    Just never saw a bad run cap trip a breaker before.
    Guess there is a first time for everything.
    Can someone please explain to me -
    Why is there never enough time to do it right the first time, but plenty of time to do it twice?
    Please view site rules: http://hvac-talk.com/vbb/showthread.php?t=1241
    Apply for Pro Membership: http://hvac-talk.com/vbb/showthread.php?t=116113
    R600a's Avatar
    R600a is offline Professional Member*/Membership Committee
    Jul 2019
    Hanging out with the mice behind the fridge talking bad about the roaches in the oven.
    Maby its internal overload didnt trip quick enough. It seems that breakers blow a lot faster than fuses.
    Quote Originally Posted by joemach View Post
    Sent from my rotary telephone using Tapatalk
    "Is this before or after you fired the parts cannon at it?" - senior tech
    I'm tired of these mediocre "semi flammable" refrigerants. If we're going to do it let's do it right.
    Unless we change direction we are likely to end up where we are going.
    "It's not new, it's better than new!" Maru.
    State College, PA
    Quote Originally Posted by R600a View Post
    No fuses. Non fused disconnects are popular around here, except if they are real old.
    R600a's Avatar
    Jul 2019
    I mentioned fuses because it seems they dont blow as often from things like that. I see breakers trip much more often. I was thinking that a fuse would likely not have blown in a similar situation.
    We have more fuses here.
    Jun 2012
    Ahoskie NC
    I have seen that one a couple of times this year. Strange though.
    Feb 2015
    Coastal South Carolina
    How did the Capacitor ohm to ground?
    State College, PA
    Quote Originally Posted by safebustr View Post
    That is a great question. I never even thought about testing that.
    Thanks for making me think.
    Mar 2018
    Kansas Flatlands
    Intresting point but it seems that way to me also. 30 yrs ago we changed a lot more fuses, especially after a lightning storm. May be these HACKR rated breakers today, don't know. Strange because now we have widespread use of scroll compressors which seem to have a higher LRA rating than that of the old recips.
    Aug 2018
    Piedmont Triad, NC
    Just had one 45 mins ago was the same problem. ~12 year old carrier with swollen capacitor and tripped breaker. It’s rare but I think I’ve had two others like it this year. I think the internal overload is taking too long to trip so the breaker steps in, or it’s a slightly weak breaker.
    Aug 2018
    Piedmont Triad, NC
    Oh, and it had a fused disconnect with good fuses.
    R600a's Avatar
    Jul 2019
    We had a trane snowball with a bad start relay that was drawing like 90 amps a second at a time till it would shut off on internal overload and it never blew the 30 amp fuses
    Sep 2019
    Run across this maybe 5 times a year. Also run across the breaker tripping for no "apparent" reason sometimes. Both seem related.
    Jul 2013
    Richmond, VA
    I wonder if the plates inside the capacitor hit the wall, which would ground through the frame. If you still got it, check resistance between each terminal and the outside of the cap.
  14. #14
    State College, PA
    Quote Originally Posted by CircusEnvy View Post
    Sorry tossed it. Wish I saved it.
  15. #15
    Dec 2015
    Ohio
    That was my first thought, shorted cap. I’ve seen it a few times. Other things I would look at too are wire size to unit, tightness of electrical connections, condition of contactor points. Is the breaker properly sized according to MOP on nameplate with properly sized conductors. I always look for stupid stuff
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
