Results 14 to 26 of 52
    Nov 2011
    East Side
    Looks like freeze damage to me. Ive seen heat pump condenser tubes that got crushed from ice buildup, and thats what they look like.
    Jan 2010
    Why wouldn't the ice crush the support as well ?
    Southold, NY
    That looks like excessive vacuum and thin wall tubing.
    And a few hundred at the scrap yard!
    Jul 2019
    Oklahoma home its in the name
    Could the either reduced operating pressure or possibly being in a vacuum when the water hammer hit have contributed to water hammer being capable of causing that damage? I don't have the slightest clue what the normal operating pressure of that system would be its just a thought.
    Sent from my rotary telephone using Tapatalk
    Oct 2006
    The Beach
    I would bet on vacuum, Never had this happen. That must have been thin tubbing.
    Blue Fox
    Southold, NY
    Cant say ive ever collapsed tubes with just a vacuum...……….there had to be other pressures involved!
    Chicago area
    Collapsed evaporator tubes - anyone seen this before??
    Cause, energy is lazy. It was easier to crush the tubes then steel support plate. That and it does appear on second look that the support plate is contouring to the pinch down of the tubes.
    Jul 2019
    It seems like if 14.7 PSI was able to crush it from the outside it wouldn't hold up to refrigerant pressure on the inside.
    Quote Originally Posted by lentz View Post
    Quote Originally Posted by PAJoel View Post
    Do you have a better picture of wire tie on the left? It looks tight. If its tight while the tubes are crushed, it could have been this way from the factory.
    "Right" is not the same as "Wise".
  10. Likes heatingman liked this post
  11. #23
    Nov 2011
    East Side
    I could buy that, except they undercharged and restarted it. it ran fine for 6 years.....if it has always been that way, it would have shown up by now.
    I've seen air cooled heat pump condenser tubes that were crushed flat inside the aluminum fins, but the fins had zero damage.....I couldn't understand how it happened without damaging the aluminum, but it did.
    this was prolly a perfect storm of several contributing factors.....
  12. #24
    Chicago area
    Quote Originally Posted by jayguy View Post
    Thats a good theory. Most heat exchangers of this design I see are rated to 300 psi or better, shell and tube side.
  13. #25
    Mar 2016
    Marengo, IL
    What is the MAWP and what was the system pressure? The failure mechanisms of burst and collapse are very different, just because something is rated for a certain internal psi doesn't mean it will hold up to the same pressures externally.
  14. #26
    Virginia
    I had a 2 door reach in cooler do that to the tube bends
    Only thing i could imagine was ice
