Page 3 of 4 FirstFirst 1234 LastLast
Results 27 to 39 of 40
  1. #27
    Central NJ Area
    What about the Bullseye Precision Gauge with Agilent 531 Sensor? I haven't had any first had use with this micron guage but those who have it love it.
    Link to their products.
    https://www.digivac.com/product-category/bullseye/
  2. #28
    Chicago area
    At that price point, they better come with a gold bar.
  3. #29
    State College, PA
    Quote Originally Posted by BBeerme View Post
    I have that exact same set up. So I must be doing something right.
    Can someone please explain to me -
    Why is there never enough time to do it right the first time, but plenty of time to do it twice?
    Please view site rules: http://hvac-talk.com/vbb/showthread.php?t=1241
    Apply for Pro Membership: http://hvac-talk.com/vbb/showthread.php?t=116113
    Find your local HVAC-Talk Contractor: http://hvac-talk.com/aop
  4. #30
    Central NJ Area
    Quote Originally Posted by heatingman View Post
    This was the only micron gauge that had a visual decay graph/test before bluvac arrived on the scene that I was aware of.
    I do like my Appion AV760 micron guage along with my BluVac pro. The app for the bluvac is much better than Appion’s app.
    I’ve been wanting to convert my vacuum pump intake to KF-16 flange connection so I don’t have to use 3/8” & 1/2” trublu kf-16 fittings. I know they have kf-16 flange style connections on large commercial vacuum pumps.
  5. #31
    Where the grass is green and the girls are pretty
    Quote Originally Posted by Nytefog View Post
    Fieldpiece had a arrow 😁
    I cut and drilled out one of the ˝ fittings and soldered it on the Jb pump. Fits nice. Was gonna do the same on the end of a couple of CVRT's eventually. Might need to go with #25 fittings though.
  6. #32
    Central NJ Area
    I like to see some pictures of your setup.
    I’ve got a jb platinum vacuum pump. Do you happen to know what the size is of the larger brass bushing that the 3/8” intake cross threads into? I was going to buy a NPT to KF-16 fitting but need the size of that large brass bushing. I figure I just use the KF-16 stainless steel Tee to connect the pair hoses to. I was Originally going remove the intake cross and replace with a 3/8” npt to KF-16 flange adapter I found online, but thought if I could replace the entire bushing and intake cross it would allow for a bit better flow. my jb pump has (2) 3/8” and (1) 1/4” intake cross that I removed from a older jb pump because I didn’t have a 1/2” hose at the time and didn’t want to use a reducer.
    Have you noticed any improvement in your pumps performance with the kf-16 intake compared to the 1/2” or 3/8” intake you had previously?
  7. #33
    The bushing is part of the integral ball valve.
  8. #34
    up in the hizzy
    I own the bullseye and love it ! definitely worth the price
    There is not better place for the working men than the union! 100% UA the only HVAC union!
  10. #36
    Chicago area
    Quote Originally Posted by valdelocc View Post
    What pump is that? A welsh?
  11. #37
    up in the hizzy
    You know it, Welch W Series 7 .
  12. #38
    Nov 2019
    Yj 69075
  13. #39
    Nov 2019
    What did you use before the bullseye? I currently use the YJ69075 for chiller work
    I like the MCS panel
