    Dec 2018
    Ultra sonic flow meter.
    Does anyone use these for chillers or heat pumps?
    How do you check the flow of the liquid trough heat exchangers?
    I have used them before. They can work very well. I usually use a pressure drop method but it certainly has it limitations.
    "Right" is not the same as "Wise".
    Nov 2011
    East Side
    they work well if you set them up correctly. you have to know the exact wall thickness of the pipe, and a few other exact details....if you're off, your readings won't be accurate.
    this more of a balancing tool than a service tool.
    Jul 2015
    Ireland
    I use the Katflow 230 from Katronic. It has the wall thickness sensor. Works great and can log the flows.
    Otherwise I use a Comdronic if the system has a DRV on it
    Aug 2019
    Central Florida
    We are using the Fuji meter , it is badass. It logs , reads wall thickness , etc . It's not cheap though .
