Results 1 to 13 of 13
    Aug 2015
    North Carolina
    Lennox Heat Pump Deal?
    Is this a good deal for a heat pump?
    It has the following model #:
    XP14-036-230-10
    Links with prices are not allowed.
    Southold, NY
    Quote Originally Posted by solicito View Post
    O
    M
    G
    Jun 2014
    Dover, DE
    Depends, what size unit do you need?
    Seen a lot of folks get burned bad on used equipment “deals” over the years.
    “I haven’t failed. I’ve just found 10,000 ways that won’t work.” - Thomas Edison
    “It’s not whether you get knocked down, it’s whether you get up.” - Vince Lombardi
    Local 486
    Aug 2015
    North Carolina
    This is what I need, a 3 ton unit heat pump.
    Athens, Ohio
    Probably not. Will the seller guarantee it is the right size for your house and that it is properly commissioned when installed? And that it is matched with the right size coil and blower?
    Or did you just want me say “yes?”
    AOP Rules: Rules For Equipment Owners.
    Free online load calculator: http://www.loadcalc.net/
    There = not here. Their = possessive pronoun. They're = they are
    It's = contraction of it is. Its = the possessive form of it
    Too = also. To = expressing motion. Two = 2
    Then = after that, next. Than = indicates a comparison.
    Questions should end with a question mark "?" Statements end with a period "."
    Athens, Ohio
    How do you know that? Is it simply what is in your house already?
    Jun 2014
    Dover, DE
    How did you come to this conclusion?
    I’d say no, it’s not a good deal. And as far as the warranty, you’ll need some luck getting it honored. At best there will be no labor warranty.
    Local 486
    Jan 2014
    New England
    What is the age and size and model number of the ID coil section, is the indoor section running on R22 now? Need to be careful when sizing a 14 SEER OD unit to even a 10-12 SEER indoor unit, especially on Heat Pumps as the coil may be physically smaller ( ID coil ) and it’s hard to get the charge adjustment correct.
    Aug 2009
    Beatrice, NE
    I'm sure it is a good deal for someone, just not sure who. Probably the seller.
    Jan 2010
    I'd buy the zero turn for a dollar instead
    It has a 10 year warranty to the person that first had it installed. It won't carry over to you.
    PS: Pricing questions are not allowed.
    Jun 2014
    Dover, DE
    Are you the same person that’s over on the DIY site asking about used units?
    Someone over there has the same link to the same unit as you did here. They were also asking about a 1.5 ton heat pump. Didn’t seem to understand sizing or what they needed very well.
    Local 486
    Jan 2019
    Vero Beach, Florida
    It’s a Lennox so you're getting screwed
