Results 1 to 13 of 39
    Aug 2001
    Pavilion, NY
    Maybe not that proud but unique
    Low headroom basement and customer wanted furnace and ac. Converted furnace to down flow into a box with turning vanes and upflow through coil. Job is obviously not done but the shell is in. 20x20 filter rack incorporated into return which is on top of furnace.
    Sent from my SM-N960U using Tapatalk
  2. Likes dbacmc liked this post
  3. #2
    Oct 2014
    Columbus, Ohio
    It looks real nice. Never mind my previous rambling, I mis-read the post and thought the air was going the other direction.
  4. #3
    Jan 2010
    I like it ! Be sure to add the completed photos.
    No room for a horizontal app most likely.
  5. #4
    Athens, Ohio
    That's a nice design and execution. What were static pressures?
    AOP Rules: Rules For Equipment Owners.
    Free online load calculator: http://www.loadcalc.net/
    There = not here. Their = possessive pronoun. They're = they are
    It's = contraction of it is. Its = the possessive form of it
    Too = also. To = expressing motion. Two = 2
    Then = after that, next. Than = indicates a comparison.
    Questions should end with a question mark "?" Statements end with a period "."
  6. #5
    Aug 2009
    Beatrice, NE
    Looks good. It will be interesting to see the finished product ans how it works.
  7. #6
    Dec 2012
    columbus, OH
    That is interesting, hope its a down flow coil
  8. #7
    Jan 2010
    Quote Originally Posted by kangaroogod View Post
    .. Converted furnace to down flow
  9. #8
    Jan 2010
    Sea to Sky
    I worked on a whole townhouse complex that had AC coils mounted farther down the ductwork in the crawl due to vertical space challenged furnace installs above the crawl. Seemed to work fine if their were no other ductwork issues.
    Sent from my SM-G965W using Tapatalk
  10. #9
    Oct 2011
    Chicagoland Area
    Thinking outside the box. I like it.
  11. #10
    Virginia
    thats pretty dam neat
  12. #11
    Mar 2015
    Hamersville, Ohio
    You couldn't put in a Horizontal Unit? And, was more R/A added than what appears to be that 7"? 8"? Round? Belay that,... with the Filter Rack, at the top,... is this pulling from a Floor Return?
    Hos 4:6 My people are destroyed for lack of knowledge. Because you have rejected knowledge, I will also reject you, that you may be no priest to me. Because you have forgotten your God’s law, I will also forget your children.
    "You've got to Stand for Something or You'll fall for anything" (A. Tippin)
    Mat_15:24 But he answered, “I wasn’t sent to anyone but the lost sheep of the house of Israel.”
  13. Likes dbacmc liked this post
  14. #12
    Aug 2001
    Pavilion, NY
    Quote Originally Posted by DavidDeBord View Post
    Horizontal would have been much more difficult. There was a 8x24 floor grill added in the floor offset left. 2 floor joists panned across above plenum and into the 20x20 filter rack that is built into the return box. The 7-8 round is actually a supply that was not connected yet. 9) 6" rounds off the plenum and since there is no heat upstairs, we are pulling a 14 round off the back and going into the attic to supply 3br and a bath on the 2nd floor. 120yr old farm house with challenging ducting. I would have liked to add return for the upstairs and not used a central return downstairs but it wasn't in his budget
  15. #13
    Oct 2011
    Gladstone, Oregon (Portland)
    Could you have made the return plenum shallower and helped out your base a little and made it taller?
