Results 1 to 13 of 20
Thread: York Simplisity
    Nov 2016
    South Georgia
    York Simplisity
    Hi all. Iím new here. Iím boggled about a Rtu York simplicity unit. The job Iím at was a start up for me and at 1st after jumping out units worked fine. But after controls were wired in Iím seeing faults shutting down ďsomeĒ of the units. I canít simply shut the units down to reset the alarms. Iíve looked thru the paperwork, googled the mess out of this control setup, and have been given a tech support # that went from them stating we donít have that info hereís another # to try..... basically I am trying to find out how to reset a York simplicity controlled unit. Any help is extremely appreciated.
    M: zwt10s18v4vae21ea7
    S: s1a9549177
    Nov 2016
    South Georgia
    I’ve noticed some posts state that it’s a good idea to have the software to work on these units. Does anyone know if a laptop has to be connected to reset the alarms on this simplicity se control?
    Nov 2016
    South Georgia
    Hey all. I finally got ahold of a tech support rep that gave me the info I needed. Didn’t need any software.
    Jun 2014
    Dover, DE
    You donít need software. But the Map Gateway is a huge help over the joystick.
    What faults were you getting?
    ďI havenít failed. Iíve just found 10,000 ways that wonít work.Ē - Thomas Edison
    ďItís not whether you get knocked down, itís whether you get up.Ē - Vince Lombardi
    Local 486
    Nov 2016
    South Georgia
    #1 fault was HS1 due to limit failure
    #2 was mixed air temp sensor failure
    Jun 2014
    Dover, DE
    Wind up replacing the mixed air sensor?
    Those are a common problem.
    Ideally you can set these units up with no sensors/thermostat in the space and they will run.
    You can also tie them together via the SA buss and see multiple units by plugging your gateway into one.
    Local 486
    Nov 2016
    South Georgia
    I want be back by till Tuesday to check it out again. This is a brand new unit that I just started up and has been working fine the past few weeks. U stated that those sensors are a common problem. Even new?
    Jun 2014
    Dover, DE
    Yup, even when new. Had some come unplugged. Some don’t come with certain sensors depending on how they were ordered.
    The first SSE I ever worked on was a 20 ton straight AC condenser. It came programmed from the factory as a packaged gas pack. JCI has to send me a run file for it.
    That little slot in the board is for a thumb drive. You can backup the board and save the information in case the board ever fails.
    Local 486
    Nov 2016
    South Georgia
    Awesome. I’ll reset everything how the rep stated to do and check the program and sensor. I’ll let u know how it turns out.
    Mar 2010
    Arnold, Mo
    Next time you may want to post in a tech to tech forum. You'll get more responses. You posted in a No DIY forum.
    Nov 2016
    South Georgia
    well now I know how to reset everything. That was a big help. Although wound up finding that the board itself was at fault. I will definitely remember to post to the tech to tech forum next time.
    Jun 2014
    Dover, DE
    Have you replaced the board yet?
    Reloading all the settings is really easy. Plus the new board will not come with the units serial number loaded in.
    Local 486
    Nov 2016
    South Georgia
    I have not. I just got back by there today to check & the rep is supposedly sending the part to that site. I’ve went thru the motions to clear faults but not reloading. It wasn’t mentioned to me. ?? I have to go back tomorrow for other things. I did see what I believe was a hard reset that was below the LOpressure reset.
