Results 1 to 13 of 24
    Aug 2012
    Portland, Or
    Walk in cooler call unbelievable 🤦*♂️
    Cooler wasnt working. New customer. Suction pressure/temp was off. 404a box. Something wasnt right. Sight glass clear and saturation temp was the same as my box temp. WTF? Was with my nephew so was the perfect call to check what the superheat and valve was doing and show him how to adjust it. Till I noticed there was NO TXV. WTF? I looked again, and told him something is very wrong or Im going to learn something. Double take at solenoid valve. Electronic? NO. Started asking customer questions he said wasnt going below 45 and was working right. I asked when box was installed. 10 years ago. Then he said well no the coil was just installed 2 years ago, was working fine. Ya right. I was going thru paperwork looking for info. He then said who installed it and said the company that did was on Lafayette Avenue. I told nephew button it up and get me model numbers, and then told customer ummmm sorry its never worked right and I know who the company is on Lafayette, and I use company loosely. I told him its never worked right and the dumb SOB forgot to install the TXV. I sent it over to my supplier and in email I said Brian I think Im missing something can you help. He calls me laughing, I think hes still laughing. Never in 25 years or his 30 years have I seen something like this. Im assuming this appliance guy and his gang of hacks thought the distributor nozzle was a metering device. LOL I just cant believe this. Box got down to 45 ish and has been running non stop for 2 years. Who in the F does shit like this? The valve was with equipment supplier checked and I saw packing slip. Wall of shame
  2. Likes trippintl0, bacciagalupe liked this post.
  3. #2
    Oct 2011
    Chicagoland Area
    We don't need no expansion valve!!!
  4. #3
    Jan 2010
    Oct 2014
    Columbus, Ohio
    I can only imagine the thought process rattling around his thick noggin: "It's a big cooler, so these giant cap tubes are supposed to be big as well, right?" LOL
  6. #5
    Apr 2010
    California
    Quote Originally Posted by Iceman_pdx View Post
    Thank You Much, for Sharing, and Making My end of Day! Take Care!
  7. #6
    Jan 2010
    His bid was one TEV cheaper
  8. #7
    State College, PA
    How the heck was that thing keeping temp?
    Can someone please explain to me -
    Why is there never enough time to do it right the first time, but plenty of time to do it twice?
    Please view site rules: http://hvac-talk.com/vbb/showthread.php?t=1241
    Apply for Pro Membership: http://hvac-talk.com/vbb/showthread.php?t=116113
    Find your local HVAC-Talk Contractor: http://hvac-talk.com/aop
  9. Likes UmmScott liked this post.
  10. #8
    Virginia
    Txv's are for sissies
  11. #9
    Aug 2013
    Omaha
    Did it even have a nozzle?
    Could be the only way it somewhat worked
    Sent from my SM-G975U using Tapatalk
  12. #10
    May 2003
    Utah
    Must have been the same "company" that installed this amazing WI Box door (which was purchased at Home Depot).
    Low bid.
    Name:  WI Box Door.jpg
  13. Likes icemeister, icy78, bacciagalupe, Turtleman liked this post.
  14. #11
    Jul 2000
    Guayaquil, EC
    Quote Originally Posted by UmmScott View Post
    I recall this being reported here on Htalk once or twice before. If they "worked" at all, they would definitely need to have a distributor nozzle installed.
  15. #12
    State College, PA
    Quote Originally Posted by icemeister View Post
    Some sort of nozzle may be making it work. The OP should check for that before putting in the TXV. Don't need 2 metering devices on one system.
  16. #13
    Jul 2000
    Guayaquil, EC
    Quote Originally Posted by joemach View Post
    Actually, with a pressure-drop type of distributor like the ones made by Sporlan, you DO need both the TXV and the nozzle. The nozzle isn't there as a metering device per se. It's needed for equal distribution and it must be accounted for when selecting a TXV because it significantly affects the available pressure drop.
