+ Reply to Thread
Results 21 to 26 of 26
Thread: N4 API data
  1. #21
    Jan 2003
    Quote Originally Posted by lasnie View Post
    Hi. Is there a way to add header to GetHTTP block? I have API where i need to put credentials in header..
    Take the source and modify it yourself. This has been disused on source forge.
  2. #22
    May 2009
    SC
    Even if this is HTTPS isn't this portion in the clear? Care about that login being lost?
  3. #23
    Jan 2003
    Quote Originally Posted by MaxBurn View Post
    Don't believe is HTTPS which is why this is a whole can of worms and no one has bothered to add support for it.
  4. #24
    Sep 2020
    Sacramento CA
    I am using GetHttp and am getting XML code on HTTP Out, what's the process of parsing out the data from the XML to something like NumericPoint?
    example;
    <?xml version="1.0" encoding="UTF-8"?>
    <result>
    <Thermostat>
    <heatSetting>70</heatSetting>
    <coolSetting>73</coolSetting>
    <temperature>70.5</temperature>
    </Thermostat>
    <success>1</success>
    </result>
  5. #25
    Jan 2003
    Quote Originally Posted by DDCDan View Post
    The easy and ugly way, use the string manipulation blocks to search for the tags you want and pull out the values.
    The cleaner method, use a program block and write your own code to parse it out.
  6. Likes DDCDan liked this post.
  7. #26
    May 2022
    Hello all,
    I am Fairly new to N4 but i am trying to expose the history data to external application using json toolkit.
    I need help on how can i parse the incoming payload sent as part of the http get and then process in my jsontoolkit inline writer
    I have tried json router and json demux router but they are separate items on my wiresheet. Is there a way to process inbound json payload and define the response based on it in same entity
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
