Results 1 to 10 of 10
    Jul 2019
    Oklahoma home its in the name
    HVACRT Fieldpiece SMAN360 tire pressure gauge
    Yep that's right heating ventilation air conditioning refrigeration and tires.
    Sent from my rotary telephone using Tapatalk
    Dec 2014
    Pretty good pics for a rotary phone
    I used my nitro tank a couple times to inflate a low tire on my service truck and my wife's minivan.
    I think I just forced it in by backing out the core slightly and exerting 200 psi thru ¼" cu tubing.
    Yours is far more refined!
    Sent from my SM-G950U using Tapatalk
    Jul 2009
    Columbia, MD
    Ive always used a refrigerant hose to charge tires.
    Maybe it’s because i keep my gaskets fresh.
    I just align it up and push it tight to the valve stem and fillerup.
    No leaking
    Apr 2003
    Maple Grove, MN
    The adapter R600 made to screw onto his refrigeration hose is handy and very easy to make.
    You can get pretty much any air chuck, along with a 1/4" MPT x male flare adapter.
    Here's an example (I actually just made one using these 2 parts about a month ago).......
    If at First You Don't Succeed, Skydiving Is Not for You.
    Jul 2019
    Quote Originally Posted by ammoniadog View Post
    I actually didnt make anything it is straight from uniweld.
    I was just geeking out on setting the tire pressure to the nearest 1/10th. It works well. I have always used the hose with core depressor backed out but i cant do fine adjustments and i cant check the pressures nearly as well.
    This was bouncing around in the bosses van never being used and well now it isnt. :-)
    Jul 2019
    I know it is pretty good for a rotary phone.
    You know what though it does a real nice autorotation on the way down when i drop it.
    Oh and that was on my wifes van. :-)
    Quote Originally Posted by icy78 View Post
  7. Likes icy78 liked this post
  8. #7
    Jul 2019
    A gasket a day keeps the leaks at bay. Or something like that isnt it? :-)
    Quote Originally Posted by gravity View Post
    No leaking
  9. #8
    Nov 2011
    East Side
    reminds me, I need to let all the air out of the car tires and inflate with nitrogen. always irritating when seasons change, and you start getting low pressure warnings.
  10. #9
    Jul 2009
    Columbia, MD
    Quote Originally Posted by 71CHOPS View Post
    Ive done this. They still go low. Just not as bad
    Convert temp to *Kelvin
    P2 = p1 * (t2/t1)
  11. #10
    Nov 2011
    East Side
    Yeah, that’s been my experience also!
