Results 1 to 12 of 12
    Feb 2015
    Short cycling fix, done.
    Finally fixed my short cycling due to over sized unit and variable blower.Name:  IMG_20190830_162121.jpg
    Sent from my GM1900 using Tapatalk
    Southold, NY
    What is that?
    Looks good from my house.
    As long as you are happy.🤪👌
    Feb 2015
    Quote Originally Posted by Advanced Response View Post
    Trick is not to cover it too much.
    Southold, NY
    Care to explain how restricting the air flow prevents short cycling?
    There is a hole behind the thermostat that the wires come thru and was not sealed properly. So the towel slows down the stack effect thru the unsealed hole.
    I guess..🤣🤓
    Athens, Ohio
    The high tech solution. Thumb gum too expensive?
    AOP Rules: Rules For Equipment Owners.
    Free online load calculator: http://www.loadcalc.net/
    There = not here. Their = possessive pronoun. They're = they are
    It's = contraction of it is. Its = the possessive form of it
    Too = also. To = expressing motion. Two = 2
    Then = after that, next. Than = indicates a comparison.
    Questions should end with a question mark "?" Statements end with a period "."
    Southold, NY
    Now what happens if the towels wet?
    Kdean,
    Bubblegum works also, chew some bubblelicious and once the flavor is gone, stick it in the hole..hehe lol🧐
    Athens, Ohio
    Kdean,
    Bubblegum works also, chew some bubblelicious and once the flavor is gone, stick it in the hole..hehe lol類
    But the wash cloth is waaay classier. It’s a status symbol.
    Feb 2015
    I'll let you work that one out since your a qualified tech.
    Feb 2015
    Quote Originally Posted by kdean1 View Post
    I'm sure an unused panty towel would have worked just as well
