Results 1 to 9 of 9
    Sep 2012
    Wink York leaking model TG8S080B12MP11A
    Our AC unit is leaking, and I don't know how to troubleshoot. I'm not afraid to get my hands dirty, so I would like to try to fix it myself, it it's not a huge job. I'm attaching two photos of where it's leaking(I wasn't sure how to describe it).
    Can anyone point me in the right direction?
    And don't worry about insulting my intelligence.
    Southold, NY
    You've got more problems then a leak!
    Flex lines are not allowed in the cabinet! From the pic get a qualified contractor to go thru the entire unit!
  3. Likes CEAS-AC-TECH liked this post
  4. #3
    Houston,Texas
    Way, way, way, more.
    “Experience is a hard teacher because she gives the test first, the lesson afterwards" ~ Vernon Law
    "Skilled Labor Isn't Cheap, Cheap Labor Isn't Skilled" ~ Unknown
    "When the teachers become unteachable we're all in trouble"
    "It's what you learn after you know it all that counts." ~ John Wooden
  5. #4
    Sep 2012
    Supposedly, a "qualified contractor" installed it. Are you talking about the yellow line?
    What all is wrong with it? Is there a way to stop the leak? I'm asking because of financial reasons.
  6. #5
    Southold, NY
    I sympathize with the financial situation but that job needs a qualified tech to go thru the entire situation.
    As you said Supposedly qualified, they / he wasn't!
    That is a fuel burning appliance that produces deadly byproducts. For you and your loved ones safety have the entire unit professionally checked and tested!
  7. #6
    Jun 2014
    Dover, DE
    Code dictates flex line cannot pass through the cabinet of the furnace, if used it instead must be terminated exterior to the cabinet wall.
    What’s with the rust? Something has been leaking for a while. Were you using the air conditioner or furnace when that photo was taken?
    “I haven’t failed. I’ve just found 10,000 ways that won’t work.” - Thomas Edison
    “It’s not whether you get knocked down, it’s whether you get up.” - Vince Lombardi
    Local 486
  8. #7
    Sep 2012
    I turned it off when I took the picture, and have left it off. Thank goodness my inlaws had extra window unit.
  9. #8
    Athens, Ohio
    The line voltage wire fastened to the gas flex connector is asking for trouble.
    AOP Rules: Rules For Equipment Owners.
    Free online load calculator: http://www.loadcalc.net/
    There = not here. Their = possessive pronoun. They're = they are
    It's = contraction of it is. Its = the possessive form of it
    Too = also. To = expressing motion. Two = 2
    Then = after that, next. Than = indicates a comparison.
    Questions should end with a question mark "?" Statements end with a period "."
  10. #9
    Southold, NY
    Please get a low level CO Detector!
