+ Reply to Thread
Results 1 to 20 of 22
Thread: 438a in a 410a
    May 2019
    438a in a 410a
    Does any one know what would happen if a 410a unit were vacuumed and filled with 438a (mo99)
    Jun 2014
    Dover, DE
    That’s an R22 substitute refrigerant.
    P/T charts are much different. I’d say it’ll run about as well as using 22 in a 410 system.
    “I haven’t failed. I’ve just found 10,000 ways that won’t work.” - Thomas Edison
    “It’s not whether you get knocked down, it’s whether you get up.” - Vince Lombardi
    Feb 2017
    New York
    Quote Originally Posted by rider77 View Post
    Which is not well?! Hahaha
    Sent from my SM-G935U using Tapatalk
    -----Stop, step back, relax and have another go at it.-----
    Jun 2014
    Dover, DE
    Quote Originally Posted by BennyD View Post
    Would not be an advised thing to do, that’s for sure.
    May 2019
    Being well aware of the differences in the two refrigerants, and the advisability, my question remains, would the compressor, not compress the gas, over compress and vaporize it, blow up, whistle Dixie, would it not condense, would or not flash, evaporate, would the metering device go nuts or stop up, to high amp's at comp to low amp's?? Thanks
    Jan 2010
    Try it and give us the results
    Southold, NY
    What test question is this!
    Feb 2017
    New York
    If I remember right from another thread, the pumping capacity of a 410 compressor is roughly 30% less than a 22 compressor. In that regard, it'll act like either a weak compressor or the condenser, evaporator and metering device are over sized. May have issues with oil return due to lower velocity. I would venture a guess of high subcooling and low superheat if the TXV couldn't choke down far enough.
    May 2019
    Thanks benny d!
    Apr 2019
    Dubai, UAE
    How it is possible to run R438a in the compressor which is designed for R410a is that possible?
    Southold, NY
    Quote Originally Posted by Anisha View Post
    The compressor doesn't know or care. Its design to pump, it pumps what it can.
    No the compression ratios are going to be way off
    Jul 2000
    Guayaquil, EC
    There would be a reduction of capacity of 40% or so when using MO99 or R22 in a R410A condensing unit meaning a 5 ton R410A unit would be roughly equivalent to a 3 ton. If you match it up with a 3 ton evaporator with a properly sized metering device it would run normally, like any other R22 or MO99 system.
    It's all about the difference in the compressor displacements (cu ft/min) between the R410A and R22 compressors. The R410A compressor simply pumps 40% less volume of gas.
    Jan 2010
    The density of the gas type must come into play here somewhere yes ?
  14. #14
    Southold, NY
    that and Lacquer Thinners!
  15. #15
    Jul 2000
    Guayaquil, EC
    The suction vapor density difference is just another way of comparing the relative capacities. My example is a comparison of the required compressor displacements.
    To do the calculations, go here: (See #3 and #18) https://icemeister.net/backroom/wp-c...lculations.pdf
  16. #16
    Jan 2010
    Quote Originally Posted by icemeister View Post
    Thanks icemeister. My thought was the compressor displacement is designed around the gas being used. Correct ?
  17. #17
    Jul 2000
    Guayaquil, EC
    Yes, it's basically a matter of scaling the displacement up or down to get the capacity you need. A manufacturer will come out with a "family " of compressors which are optimized for specific refrigerants like R410A, R404A, etc and for specific applications like high temp. low temp, etc. Copeland rates some models for a number of alternate refrigerants and applications.
    This "optimization" usually involves designing the scrolls for a particular refrigerant and application to boost efficiency at specific conditions.
  18. #18
    Mar 2013
    Treasure coast, FL
    Yeah, based on the enthalpy of the refrigerant at the conditions the system would need to operate at, which dictates the volume that the compressor needs to move.
    Sent from my Moto Z (2) using Tapatalk
  19. #19
    Poodle Head Mikey's Avatar
    Poodle Head Mikey is offline Membership Chair/ARP Committee / Professional Member*
    I try to stay as far away from myself as I can.
    It would operate at about 65% of the R-410 unit's rated capacity.
    PHM
    Quote Originally Posted by waterworksdan View Post
    PHM
    When faced with the choice between changing one's mind, and proving that there is no need to do so, most tend to get busy on the proof.
  20. #20
    If the R-410 system metering device was a fixed orifice - it would operate well but at about 65% capacity as compared to R-410.
    If the R-410 system's metering device was a TXV it would tend towards low suction superheat - because, to a R-410 TXV, the suction pressure (a closing force) would appear to be "too low" to the TXV.
    PHM
    Being well aware of the differences in the two refry the igerants, and the advisability, my question remains, would the compressor, not compress the gas, over compress and vaporize it, blow up, whistle Dixie, would it not condense, would or not flash, evaporate, would the metering device go nuts or stop up, to high amp's at comp to low amp's?? Thanks
    PHM
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
