Page 3 of 3 FirstFirst 123
Results 27 to 33 of 33
  1. #27
    Southold, NY
    Quote Originally Posted by heatingman View Post
    What do you consider yourself? Mr Exhaust fan?
    Refrigeration and Industrial. These toy fans are easy, try a fan you can stand in the wheel!
  2. #28
    Aug 2009
    Beatrice, NE
    Sounds more like a human hamster wheel.
  3. #29
    Southeastern Pa
    Quote Originally Posted by BNME8EZ View Post
    I heard you can buy them online.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  4. #30
    Chicago area
    Ive done plenty.
  5. #31
    Feb 2016
    Louisburg Kansas
    The main thing wrong with the exhaust fan in the picture is the variable pitch sheave is adjusted wrong and the driven sheave is wore out.
    No man can be both ignorant and free.
    Thomas Jefferson
  6. #32
    Aug 2019
    I want to thank everyone for their input. I spoke the the GM and the POC at the site, and they said they thought it would last longer. I told them that at the end of the day, it’s their equipment and we’ll do what they ask us to, but the manufacturer (Bosch) recommends A belts. I’ll keep tabs on the 75 units they have that use belts to see what happens as they run.
    We’ll also report back the motor amp draw and any enthalpy differences from using a B belt instead. When it gets slow in Florida “winter”, it gets SLOW.......
  7. #33
    Apr 2003
    Maple Grove, MN
    Quote Originally Posted by Amwilson10478 View Post
    We'll also report back the motor amp draw and any enthalpy differences from using a B belt instead.......
    You should adjust the sheaves so that the amps are about the same as before. Definitely check the amp draw and make adjustments as necessary so that the motors don't exceed nameplate FLA.
    You might also have to go up a size on length. I'm sure the first few will be an experiment.
