+ Reply to Thread
Page 3 of 3 FirstFirst 123
Results 41 to 60 of 60
Thread: Refrigeration
  1. #41
    Aug 2019
    Idontgetit, thanks but the door to be opened and closed at least 40times a day. Switching fan for 40times per day is a NB big issue.
  2. #42
    Aug 2019
    Quote Originally Posted by BALloyd View Post
    I would try adding insulation to the middle of the door before anything else. Heat getting I is melting your ice.
    Sent from my SM-G965W using Tapatalk
    Thanks but even at night when the atmosphere is cool, it keeps melting.
    Sent from my S61 using Tapatalk
  3. #43
    Poodle Head Mikey's Avatar
    Poodle Head Mikey is offline Membership Chair/ARP Committee / Professional Member*
    I try to stay as far away from myself as I can.
    Why 40 times or more openings per day?
    PHM
    Quote Originally Posted by Ahmedgee View Post
    PHM
    When faced with the choice between changing one's mind, and proving that there is no need to do so, most tend to get busy on the proof.
  4. #44
    Can you build a small insulated room / area over the ice storage chest and air condition the room to say 75º or less?
    PHM
  5. #45
    Jun 2014
    Dover, DE
    I’m confused on two things here-
    Why is the door opened and closed so many times for a simple ice block freezer?
    Making ice doesn’t require an exceptionally low temperature environment. What is the holding temperature of this box where it’s unable to freeze certain parts of the block?
    “I haven’t failed. I’ve just found 10,000 ways that won’t work.” - Thomas Edison
    “It’s not whether you get knocked down, it’s whether you get up.” - Vince Lombardi
    "In this house we obey the laws of thermodynamics" - Homer Simpson
    Local 486 Instructor & Service Technician
  6. #46
    Jul 2000
    Guayaquil, EC
    The ice blocks are made in another unit. This chest freezer is only for storage of completed blocks.
  7. #47
    Oct 2016
    Clearwater, Florida
    I don't even understand what he's trying to do or what the equipment is.
    Anyone willing to explain it to me? Perhaps I can help.
  8. #48
    Aug 2019
    Quote Originally Posted by Poodle Head Mikey View Post
    The iceblocks are used to cool soft drinks and bottle water for commercial purposes so the iceblocks are expected to be very dry so as to last long. It won't retain its form Using air-conditioned room. This is Nigeria, temp of about 36 Deg cent.
  9. #49
    Aug 2019
    The iceblocks are to be used in areas without power supplies for commercial purpose. Transportation is not via refrigerated van.
  10. #50
    Aug 2019
    PHM
    It's sold at retail level at sale site. At least 40 buyers come at different times.
  11. #51
    Aug 2009
    Maine
    Why not build a small cooler that you would walk through to get to freezer door?
  12. #52
    You miss my point.
    If the door / hatch / lid / or whatever you are opening was inside of another room - which was cooled to, for example; 70º F. - the ice under the center of your storage facility would not melt. Because the air over the lid would not be 97º F.
    So you would NOT need more lid insulation OR more storage box refrigeration.
    Build a 25' by 25' by 7' walk-in box over your present storage chest and cool it to some lower temperature: 40-50-60º F.
    I have am running out of imagination. Make it easier on me: Post some pictures. <g>
    PHM
    PHM
  13. #53
    OOOh OOOOh Pics are comin ! YAY I love pics ....
  14. #54
    Southeastern Pa
    I am also having a hard time picturing this.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  15. #55
    Oct 2016
    Clearwater, Florida
    Is the idea to run refrigerated tubing at the door openings to keep it cooler? Like adding an overhead cooling source?
  16. #56
    Jul 2000
    Guayaquil, EC
    Quote Originally Posted by Olivero View Post
    From the way the OP describes it, this is constructed much like a typical home chest freezer with the evaporator in the walls, except it's huge...15 ft x 15ft x 5 ft high. He wants to add evaporator tubing to the door, which is the top of the box. The added refrigeration to the top is intended to solve a the problem of the ice melting in the center of the box.
  17. #57
    Oct 2016
    Clearwater, Florida
    Wow, okay.
    So how do they get the ice blocks out if it's 5' tall, how big are the ice blocks?
    What about a suspended evaporator or something of the sort near the center?
  18. #58
    Aug 2009
    Maine
    Cold room?
  19. #59
    Jan 2010
    Walk-in freezer, problem solved.
  20. Likes Turtleman liked this post.
  21. #60
    PHM
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
