+ Reply to Thread
Results 1 to 20 of 59
Thread: Walk-in Freezer Superheat
    Virginia
    Ok its not running right
    Ok so I went with a 7000 btu evap by Trenton TPLP207LE-S2B-R6 according to the sheet i saw online
    ( dealer called it a 7500 for some reason )
    Compressor is
    5170 BTUH @ -20 SST @ 90 AMB
    7160 BTUH @ -10 SST @ 90 AMB
    a day later it wont pull below 15 , just hovers there
    I go check it out
    Ambient outside 80
    High 265
    Low 42
    Line Temp 15 ( at pump )
    So I have 5 deg SH
    Had some bubbles so I topped it off , no change
    Evap clean , no snow
    Crank the TXV ( in ) a bunch of turns , didnt see much change
    Turn all way in , back out 1 turn ( i dont like to leave them snugged in )
    Low 38 psi , Line Temp 11
    STILL 5 DEG SH
    Didnt check SC , but the filter felt like your typical warm drier
    Lineset length 12 ft
    Virginia
    aint the neatest , but its functional
    AND its a 6 x 8 x 7 box
    I was guessing on the original post
    Jul 2000
    Guayaquil, EC
    My initial thought says the TXV isn't doing what it's supposed to do...ie, control superheat.
    Did somebody assemble this valve for you and forget to put a cartridge in it? I've heard of that before.
    Virginia
    It come pre-assembled , i tore out the old evap , and just hung the new
    I strapped the bulb directly outside the cabinet
    Jul 2000
    Guayaquil, EC
    Quote Originally Posted by Snapperhead View Post
    Never trust, therefore verify. Replace the valve.
    Jul 2000
    Guayaquil, EC
    I once forgot to tighten down the cartridge in a Sporlan Q valve and got the same kind of floodback.
    Jul 2000
    Guayaquil, EC
    BTW...I've asked for this to be moved to a new thread.
    Made this its own thread.
  9. Likes icemeister liked this post.
  10. #9
    Poodle Head Mikey's Avatar
    Poodle Head Mikey is offline Membership Chair/ARP Committee / Professional Member*
    I try to stay as far away from myself as I can.
    The TXV came with assembled to the evaporator coil -
    Is there sub cooled liquid refrigerant at the TXV inlet?
    Is the TXV bulb's full length snug and secure to the suction line?
    If the TXV correct for the system's refrigerant?
    If three yes answers the TXV is defective or the inlet screen is plugged.
    PHM
    Compressor is
    I go check it out
    Ambient outside 80
    High 265
    Low 42
    So I have 5 deg SH
    STILL 5 DEG SH
    PHM
    When faced with the choice between changing one's mind, and proving that there is no need to do so, most tend to get busy on the proof.
  11. #10
    Southold, NY
    Good Job!
  12. #11
    Jan 2010
    Is there a question in here somewhere ?
    As for the head line ..... I like 4-6 @ the evaporator.
  13. #12
    Jan 2010
    Wait a minute, if he's flooding back the coil can't be starving.
  14. #13
    Oh you're right - doing too many things at once here. Delete my inlet screen reference. <g>
    Can you think of any thing else I have overlooked?
    PHM
  15. #14
    Jan 2010
    What's the defrost setup ?
    Personally I'd eliminate them till frost shows up.
    Also what were the TEV spec's ?
  16. #15
    Atlanta - Retired
    What is the compressor number?
  17. #16
    Virginia
    Walkin freezer super heat is pretty effective when set right
  18. #17
    Virginia
    CF06K6E-PFV-25S
  19. #18
    Virginia
    4 times a day 30 min
    TEV specs ? I asked for a 404a coil
    I glanced at the power head , its a zp with 404 label
    Didnt take amp readings
    He just called said its holding 11 deg
    I told him shutter down until i can get back tomoro
    I will yank that TXV apart
  20. #19
    Jan 2010
    Did you by chance get a amp reading ?
  21. #20
    Aug 2009
    Maine
    I use 5. look for 30 or less at compressor
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
