Results 1 to 13 of 13
Thread: No cool load
    Jul 2015
    Ireland
    No cool load
    Does anyone know why some York chillers display a 'No cool load' when clearly there is a cool load and sometimes you got to drop the setpoint to start a compressor?
    ottawa canada
    Differential to start ?
    Jul 2015
    Ireland
    Nope. Had one today. Set point at 7 DegC. Range at 1 DegC. LWT was at 11 DegC. Not controlled by remote set point either. Had to drop set point to 5 before it would kick in a compressor. YLAA chiller.
    Seen it happening on a YCAJ also.
    Aug 2019
    LA
    Software internal load timers. If load is dropping at current demand timers will stop and start on temp fall speed
    Jul 2015
    Ireland
    But the chiller is off and waiting to start. The CHW temp is climbing and she still doesn't kick in?
    Just sits there with no cool load.
    Aug 2009
    Prattville, Alabama
    Is there some kind of chilled water reset that is affecting the setpoint? So that the "active" setpoint is higher?
    In honor of RichardL: "Ain't 'None' of us as smart as 'All' of us".
    Aug 2019
    LA
    quote from the book
    1) The display will show the anti-coincidence timer status for the lag compressor, followed by ‘NO COOL LOAD’ until it is called to operate by the control system.
    2) LLSV off
    Internal timers. For what, I’ll try to find out
    Jan 2013
    United Kingdom
    Was it on local control or remote ?
    Jul 2015
    Ireland
    In local model. She likely would have started. Just that I was on site at the time.
    it had gone to 11 DegC and still said no cool load.
    i had system # 2 switch off as i was doing a service on it. But sys # 1 just sat there with no cool load and the temp was up at 11.
    Dropped it down to 5 and she kicked in the first compressor, put the setpoint back to 7 as that what the site wants and she was fine.
    It has a +/- 1.1 diff.
    BMS just monitors for alarms, everything else is chiller controlled.
    Jan 2013
    United Kingdom
    Auto lead lag or manual ?
    Jul 2015
    Ireland
    Auto Lead lag Raptyr.
    Auto restart after power failure ect
    There is actually noting wrong with the chiller, just I'd like to know whey it happened.
    I also seen it happening on a YCAJ many moons ago, and never got to the bottom of it.
    Jan 2013
    United Kingdom
    I would see it happen occasionally on YKs and I never got to the bottom of it , I would reboot and everything was fine for a few more months, updated software too but never knew if that really fixed it. I think the logic gets stuck in a loop and goes around in circles under certain circumstances and you just have to break the cycle to wake it up and get it working normally again.
    We ran on simulators too in York but could not replicate the problem
    Nov 2011
    East Side
    I’ve had 2 YCWS’s at one site do that occasionally. It happens maybe once a year, if that. They’re about 10 years old.
