Results 1 to 2 of 2
    Aug 2019
    Confused Hobart LXeR Fill Error
    I'm working on a Hobart LXeR dishwasher and I had the dishwasher working fine but the detergent dispensers were not working properly. So I had a tech come out (Not a Hobart Tech) and replace the tubes for the dispensers. As he was pushing the machine back under the counter the water drain line came off and sprayed water everywhere. He put the drain line back on and when he pushed it back in and started it up and came on with a fill error code (Check Water Supply). I thought it could be a loose wire or maybe a blown fuse but everything seems to be fine. Any Ideas??
    Jul 2018
    Burlington, Vermont
    Is there anyway the water supply hose got kinked? Or is there water in the sump and it’s not sensing it?
