+ Reply to Thread
Page 5 of 7 FirstFirst 1234567 LastLast
Results 81 to 100 of 129
Thread: Alum micro channel fix
  1. #81
    Virginia
    1st day I tried Flux with Alum .... didnt you see the big ass picture ? on page 1
    2nd day tried hobart rods that supposed to have flux in it ( the weld actually looked nice ) and it adhered to the header nicely , which made me very surprised it kept leaking
    It would have like 2 tiny ass spots where micro bubbles come thru EVERY DAM TIME
    So I would heat it back up , sweep off the alum , hit with stainless brush , and start over
    Did this probly 50 times
    3rd day , tomoro mornin , will be Epoxy
  2. #82
    Poodle Head Mikey's Avatar
    Poodle Head Mikey is offline Membership Chair/ARP Committee / Professional Member*
    I try to stay as far away from myself as I can.
    I have a different opinion.
    Force is pressure times area. So a micro-leak has almost no outward force. I would think that wildly wire brushing the entire area clean and bright and then putting a layer of pretty much any epoxy over the area would work to prevent further leaking.
    PHM
    Quote Originally Posted by icemeister View Post
    I doubt the epoxy is going to work now that there are no microchannels left to plug.
    PHM
    When faced with the choice between changing one's mind, and proving that there is no need to do so, most tend to get busy on the proof.
  3. Likes R600a liked this post.
  4. #83
    Chicago area
    Im with PHM, it should work fine. The header is cast like in finish, and the ports are not smooth, so there should be ample surface area and roughness to promote a good bond.
    And the area of the ports are tiny, maybe
    .025 diameter
    So if I did the math right, thats like .25 lbs of force at 500 psi.
  5. #84
    Mar 2019
    Milwaukee
    I’ve tried it a few times, and I have luck about 50 percent of the time. I feel like when it failed it’s always heat related, and I got the aluminum too hot, or maybe I needed to spend some more time cleaning. I’ve only used that York kit in all my tries though, I’m sure there is something better out there. I suppose if they were getting a new coil anyways I would try the epoxy.
  6. #85
    Oct 2016
    Clearwater, Florida
    Was it flux specifically for aluminum? It's a specific thing, was there a color on the Hobart rods?
    Could be it's just doomed in this case but I just have a hard time believing it is all, I've had a lot guys come up to me asking me why they can't TIG aluminum worth a damn and it's ALWAYS something simple, too much stickout, too little gas, wrong settings, I've welded some of the nastiest aluminum and it ain't always easy but it's doable.
    Brazing is a different beast, it's true. Are you using Mapp still or did you switch to oxy acetylene?
  7. #86
    Virginia
    Quote Originally Posted by Olivero View Post
    Are you even reading the posts ? I told Poodle I would try mapp , oxy , propane , and I even bought a butane torch , but that wouldnt get it hot enough , Ive literally tried almost everything in town
    Nawwww dude I used a G Dam crayon
  8. #87
    Aug 2008
    Hibbing, MN
    Quote Originally Posted by Snapperhead View Post
    That’s hilarious!
    If God didn't want us to eat animals... He wouldn't have made them out of MEAT.
  9. #88
    Oct 2016
    Clearwater, Florida
    Sorry, I don't remember ever single post on these threads.
    Fair enough, I guess it just don't work then.
  10. #89
    Jan 2010
    Was it at least a metal marking type ?
  11. #90
    Well; how about another approach then?
    What capacity is the unit in question? If five tons or less - just pipe in a residential condensing unit and run the power and compressor contactor coil wires over to the condensing unit. I have done that a number of times.
    Also: you can always pipe in a "dry cooler" type of condenser-only unit. I've done that for badly damaged condenser coils on RTU's.
    PHM
  12. #91
    Virginia
    The eagle has landed fellas , Red Epoxy saved the small business , pics later
  13. Likes heatingman, R600a liked this post.
  14. #92
    Jul 2000
    Guayaquil, EC
    Jul 2000
    Guayaquil, EC
    Good news!
  16. #94
    Jan 2010
    Do you get a free lunch ?
  17. #95
    Oct 2016
    Clearwater, Florida
    Wow, perhaps my distrust in epoxy and adhesives is misplaced.
  18. #96
    Virginia
    Torched all of the aluminum weld off and sanded
    Top picture is old picture .... whoops ... lemme try again
  19. #97
    Virginia
    cleaned up channel by breaking off the old section ..... sliced thru horizontal with knife , then took needle nose and bent back n fourth until it snapped
  20. #98
    Virginia
    when heating it turns liquid like , then after 5 minutes it turns yellow
  21. #99
    Jan 2010
    Come-on where's the poxy ?
    Ahhh..... Thank you
  22. #100
    Virginia
    before heat gun ..... after heat gun
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
