Results 1 to 11 of 11
    Apr 2019
    Dubai, UAE
    Usage of R404a refrigerant.
    Hi, dear members can you please answer this question? I am in need of an answer In which machine is R404A used?
    up in the hizzy
    Just one machine???...Manitowoc Indigo Series.
    There is not better place for the working men than the union! 100% UA the only HVAC union!
    Oct 2008
    Anisha, there are hundreds upon HUNDREDS of machine models which use that. It's the most commonly used refrigerant used in REFRIGERATION applications - especially ice machines and low temp.
    "You never know what others don't know." -
    If I can't laugh at myself...then I'll laugh at YOU! -
    Apr 2019
    Dubai, UAE
    Is R404a refrigerant is an Eco-friendly refrigerant?
    Oct 2008
    Apr 2019
    Dubai, UAE
    Thanks for the article it's very nice and informative.
    Oct 2016
    Clearwater, Florida
    R404 is not environmentally friendly, no.
    The only refrigerants I think are considered to be close to eco friendly is propane and butane, R290 is being used as a replacement for other refrigerants like R134A, R22 and probably 404A in med temp.
    It's used in refrigeration though, 404A is not used in any residential I've ever seen.
    Jul 2002
    Chariton, Iowa
    As I understand it 404a is used in applications that use hot gas bypass because it has a higher heat of compression, for instance hot gas harvest ice machines.
    Quote Originally Posted by danielthechskid View Post
    Its used in a lot of applications that don't have hot gas bypass/hot gas defrost.
    Oct 2011
    Chicagoland Area
    All refrigerant is eco friendly as long as the system isn't compromised with leaks.
  11. Likes bacciagalupe liked this post
  12. #11
    Jan 2010
    Today it's the best refrigerant to replace the old R12/ R502 refrigerants.
