+ Reply to Thread
Thread: rheem icc dual drive issue
    Dec 2003
    Sugar Land, Tx
    just came across icc in UASL-060JEC, icc on compressor B code 27, line voltage missing, checked 242 volts at board, pushed test, compressor fires for 5 sec then goes off, voltage remains at board yet continues with code 27.
    I'm going to call bad icc board and replace. Just wanted to verify as this is a first for me with icc comfort alert.
    Techson Mechanical LLC
    "We Shall Mount Up Wings As Eagles"
    Mar 2018
    Kansas Flatlands
    Quote Originally Posted by techsonac View Post
    Did you unplug the low voltage to both boards and see if it reset? Have the board with you but you may get it to reset.
    FYI those comfort alert boards are very vunerable to water, be real careful when you wash a condenser. They can lock out when you don't even get them wet.
    Dec 2003
    Sugar Land, Tx
    Thanks, will try method before replacing. Not that it makes any difference, but this was a ruud and its tandem comp. Other board seems fine. Let you know what happens.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
