Results 14 to 18 of 18
    May 2013
    Sometimes...before I go to install the valve....I will braze on a copper stub with the stub facing up and the tip pointed away from the valve, and then use a coupler with the valve all wrapped up to be able to braze the other end of the stub to the assembly....that way I don't have that much mass drawing away heat from the final connection.
    This is exactly what I also do. Not only does it make your job easier, but the next person's also. I don't think I've done a direct TXV to distributor in 25 years, mine would be ugly if tried at this point.
    Apr 2003
    St. Louis
    You all work to hard! Buy a new distributor, tubing and couplings. First solder 12" tubes in distributor and couplings then the valve all on a pipe vise in the comfort of being on the ground not standing on your head and a stub on the liquid side. Imp cut all the dist tubes and liquid. For some reason it's easier to solder up 3/8 tubes than the whole dist. Your head won't hurt as bad or your body and save time.
  3. Likes gravity liked this post
  4. #16
    Jul 2009
    Columbia, MD
    Should have used staybright8
  5. Likes Brian8383 liked this post
  6. #17
    Jul 2010
    napping on the couch
    Great advice here. One more I'll add is wet rags will dry out on some of the bigger jobs before you finish. I keep a spray bottle full of water and spray the rag down occasionally while I have the heat on the joint. Even if the outside of the rag is still kind of wet, where the rag hits the metal will dry out first.
    “Free men do not ask permission to bear arms.”
    -Possibly said by Thomas Jefferson(but true even if he didn't)
    “What one generation tolerates, the next generation will embrace.”
    ― Definitely said by John Wesley
  7. #18
    Jul 2010
    I wrap the distributor tube assembly with a rag just to keep those from popping out.
    I'll usually do this also. An extra inch or two matters.
    (Insert joke here).
