Results 1 to 13 of 18
    Jan 2012
    Missouri, USA
    My first big tev kicked my butt.
Size:  111.9 KBName:  FC42E006-3E52-4A28-AF1B-8C6189ED1515.jpg
Size:  110.9 KBName:  35605325-CA61-4EA3-857D-070A06D9BFC8.jpg
Size:  106.7 KBName:  A815CBA0-61B9-4EFF-8A56-099B75D9E227.jpg
    First I found that the brazing tip on my torch kit was too small to unbraze the old txv. I drive 45 minutes for a rosebud tip. Then after many failed attempts to braze the new valve I ran out of n2 and acetylene. Used 3 full bottles of each, the big rosebud used a mc bottle in about 5 minutes. After waiting 90 minutes for the on call guy to help with more gas and more experience, we called it a day at 10:30 pm and it still leaks. I thought it was going to be just another easy txv day. Got home after the 2 hour drive about 12:30 and back this morning at 6 on a different job, I wanted to fix it myself.
    Jan 2012
    Missouri, USA
    3rd pic upside down, oops.
    Southold, NY
    Valves that large I completely disassemble then braze.
    Wet rags and thermos block doesn't cut it.
    kansas
    or just rebuild the valve
    Athens, Ohio
    Yeah, there's a lot of mass to heat up to braze those. They are a challenge.
    Good for you on staying with it to finish it.
    AOP Rules: Rules For Equipment Owners.
    Free online load calculator: http://www.loadcalc.net/
    There = not here. Their = possessive pronoun. They're = they are
    It's = contraction of it is. Its = the possessive form of it
    Too = also. To = expressing motion. Two = 2
    Then = after that, next. Than = indicates a comparison.
    Questions should end with a question mark "?" Statements end with a period "."
  6. Likes Core_d liked this post
  7. #6
    Southold, NY
    Quote Originally Posted by crazzycajun View Post
    Had to do that on a Carrier Chiller. Much easier then all the Burn Permit BS!
  8. #7
    Nov 2011
    East Side
    You likely have your gas pressures turned up too high. A rosebud tip doesnt require any more gas than a standard tip. Set your pressures at 7/7 and adjust from there, if necessary. I braze 130 ton TXVs at those pressures.
    Use heat paste around the body and wrap in wet rags. Braze one side, pour water on to cool, then braze the other.
    Make sure to clean everything as well as possible, and use flux on the fittings you unbrazed. Sometimes I will cut the old inlet side piping braze joint off, so I have fresh copper.
  9. Likes Lahrs, Brian8383 liked this post
  10. #8
    Oct 2005
    B.C. Canada
    The best is when the distributor tubes start popping out! Gah!!
  11. Likes Brian8383 liked this post
  12. #9
    Jan 2012
    Missouri, USA
    Thanks for the advice, the next one will be better.
  13. #10
    Nov 2011
    East Side
    Quote Originally Posted by coolerik View Post
    I fill them with heat paste and rags!
  14. Likes Brian8383 liked this post
  15. #11
    Nov 2011
    East Side
    Quote Originally Posted by ksefan View Post
    Get some scrap and practice with the rosebud. Once you get used to it, youll prolly only use that.
  16. Likes Brian8383 liked this post
  17. #12
    Southeastern Pa
    I wrap the distributor tube assembly with a rag just to keep those from popping out.
    Sometimes...before I go to install the valve....I will braze on a copper stub with the stub facing up and the tip pointed away from the valve, and then use a coupler with the valve all wrapped up to be able to braze the other end of the stub to the assembly....that way I don't have that much mass drawing away heat from the final connection.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  18. Likes Lahrs liked this post
  19. #13
    Aug 2016
    Houston TX
    Replacing the TXV on a brand new unit? Wonderful carrier quality control. They likely over heated it in the factory. Good job staying on it though.
