Results 14 to 16 of 16
    May 2013
    Sometimes...before I go to install the valve....I will braze on a copper stub with the stub facing up and the tip pointed away from the valve, and then use a coupler with the valve all wrapped up to be able to braze the other end of the stub to the assembly....that way I don't have that much mass drawing away heat from the final connection.
    This is exactly what I also do. Not only does it make your job easier, but the next person's also. I don't think I've done a direct TXV to distributor in 25 years, mine would be ugly if tried at this point.
    Apr 2003
    St. Louis
    You all work to hard! Buy a new distributor, tubing and couplings. First solder 12" tubes in distributor and couplings then the valve all on a pipe vise in the comfort of being on the ground not standing on your head and a stub on the liquid side. Imp cut all the dist tubes and liquid. For some reason it's easier to solder up 3/8 tubes than the whole dist. Your head won't hurt as bad or your body and save time.
  3. Likes gravity liked this post
  4. #16
    Jul 2009
    Columbia, MD
    Should have used staybright8
