Results 1 to 4 of 4
    May 2019
    replacing 2.5 ton central with mitsubishi multi position
    i want to replace 2.5 ton central ac unit with 3 ton Mitsubishi heat pump.my only problem is that existing system have 1000-1200cfm and mitsubishi multi position air handler 767-910cfm .. the house is only 1200sqf one floor. Never install Mitsubishi ducted air handler so i dont know how does it work, end if its going to be strong enough,or i should just go by tonnage and count on Mitsubishi design engineers. please any suggestions??thank you.
    Southold, NY
    Doesn’t 3-Tons seem large?
    May 2019
    well. i was thinking about 30k btu but its cfm its even lower.do you suggest to just go by tonnage and to not worry about blowers cfm??? than you so much..
    Southold, NY
    No I suggest you do things in order
    Manual “J” for proper sizing
    Manual “D” to match the Ducts to the unit!
