Results 14 to 19 of 19
Thread: old fridge
    New Mexico
    In very early compressors it was said the compressor might come off it's mounts. I never saw that but there is a real possibility of oil leaking past the piston rings and filling the upper chamber. Starting could blow the valves.
    I was gifted a freezer long ago. It was flat and I saw an opportunity. I would fix the leak and have a freezer. What I found though was the condenser was made of steel. The insulation was made of sticky rubber (forgot the name) passed moisture and the pipe had pin holes all through the length.
    Prognosis = crappy. Know when to bail.
    Lesson: Don't think every freebee is a good deal.
    Good thing I had no emotional attachment.
    Give me a relay with big enough contacts, and I'll run the world!
    You can be anything you want......As long as you don't suck at it.
    If a person wants to create a machine that will be more likely to fail...Make it complicated.
    USAF 98 Bomb Wing 1960-66 SMW Lu49
    Oct 2011
    Gladstone, Oregon (Portland)
    Its all about the oil. We could start a thread about heat pumps and crankcase heaters and there would be differing opinions as well.
    May 2014
    Bay Area California
    Where's the oil going to go when you lay a fridge on it's side?
    Quote Originally Posted by Adlerberts-Protege View Post
    I use 56% silver on everything except steel.
    Did you really need the " If you were a real tech " ??
    Jan 2010
    May 2014
    Bay Area California
    So, the oil stays in the crankcase. Got it. Thanks.
    Mar 2015
    Hamersville, Ohio
    Hos 4:6 My people are destroyed for lack of knowledge. Because you have rejected knowledge, I will also reject you, that you may be no priest to me. Because you have forgotten your God’s law, I will also forget your children.
    "You've got to Stand for Something or You'll fall for anything" (A. Tippin)
    Mat_15:24 But he answered, “I wasn’t sent to anyone but the lost sheep of the house of Israel.”
