+ Reply to Thread
Results 1 to 7 of 7
Thread: Trane rtaa 70 low pressure fault.
    Jan 2001
    Carlisle, Pa
    I have a chiller that trips once a day or so. The charge looks fine. I am going to replace switch. Any other ideas besides exv hanging up. Thanks
    ottawa canada
    The low pressure switch is opening .
    I"m not a service tech, I’m retired ….I used to be a thermodynamic transfer analyst & strategic system sustainability specialist
    Sensors beginning to fail, flow switch is hung up
    "Right" is not the same as "Wise".
    Just because you can measure it, doesn't mean it is important. Just because you can't measure it, doesn't mean it isn't important.
    Indiana
    I have had those Texas instrument low pressure peanut switches trip way to soon, you need to see if that's happening. They normally have valve cores under them.
    Jan 2001
    Carlisle, Pa
    It is to open at 7# (r22). I checked charge on both circuits. It's fine. I had to replace lvg water sensor in July. I checked flow back then it was fine. This thing may trip once a day. It went all weekend without tripping. I am replacing low pressure switch tommorrow. If it continues the only thing I could figure is exv isnt opening all the time. I guess it could be suction sensor too.
    Sunrise,fl
    Checked ampage on startup.Make sure compressor is not starting loaded.That could also cause issue.
    Jun 2010
    U.A. (upper Alabama)
    Check the male unload solenoid coil. May be loading but not unloading when it needs to. Seen a few bad unload coils that will cause problems with low evap temp and low pressure cutout.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
